I have a problem with my qnapcloud link.
If I type in the browser https://myname.myqnapcloud.com I get the message
Connection time exhausted
The myname.myqnapcloud.com server is taking too long to respond.
The site may be unavailable or overloaded. Please try again in a few moments.
If no pages load, check your computer's network connection.
If your computer or network is protected by a firewall or proxy, make sure Firefox has permissions to access the Web.
Instead, if i write: https://nyname.myqnapcloud.com:8082 I regularly display the login page
Is there any way to do a redirect from the url without the port number to the one with the port number?
Or am I doing something wrong in the configuration?
Thanks for the help
myqnapcloud link without specifying the port
Re: myqnapcloud link without specifying the port
use cloudlink if you absolutely have to use a remote connection without vpn
everything else is very dangerous and should be disabled immediately (malware attacks)
Thanks for your advice, but I can't give up.
Do you have any suggestions regarding my issue?
https://www.qnap.com/en/security-advisories/
sorry you should give up...unless you like to get hacked
a tiny hint towards your doom...ports can be translated
wanport>lanport
wanport>lanport
- spile
- Been there, done that
You don’t need to open ports to use MyQnapCloud Link. If you are unable to log into your account open a call with Qnap support.
if you are not using a special link to access..it's not cloudlink .. but just ddns with portforwarding
https://www.qnap.com/solution/myqnapcloud-link/en-us/
I think I understand what you mean.dolbyman wrote: ↑Sun Dec 20, 2020 10:54 pm if you are not using a special link to access..it's not cloudlink .. but just ddns with portforwarding
I have a smart URL generated by qnapcloud link http://qlink.to/myname
The 2 questions though that come to me are:
1) If my users try to log in I ask them to create a QNAP Account ID.
2) Can I use the same smart link to configure QSync?
Thanks again for the help
