TS-1279U-RP stuck on blue LOADING screen
Post your questions about myQNAPcloud service here.
MOS6510
Post by MOS6510 »
Our TS-1279U-RP GUI stopped working, no changes were applied to the NAS. Plugging a monitor directly to the VGA port also does nothing, it displays a black screen. Apart from that the NAS is fully accessible via SSH, I can browse all files from windows etc.
I managed to update the firmware to the latest version (TS-1279U_20210504-4.3.6.1663) using QFinder, unfortunately that didn't solve the issue. I then followed Step 1 from this guide a
https://tinyurl.com/2tnhsw4e
nd deleted the /etc/config/.qos_config/users/admin folder, after rebooting the box the OS created the folder again but GUI is still stuck on a blue LOADING screen. Opening it in a second tab trick doesn't work either.
I'm a bit reluctant to pull out the drives and running commands in the 2nd step - would this delete all shares and data? Any advice appreciated.
dolbyman
Re: TS-1279U-RP stuck on blue LOADING screen
Post by dolbyman »
please use a link shortener for these URL's they get censored by the forum
Have you tried
-using a different browser or machine
-reinstalling the current firmware
MOS6510
Post by MOS6510 »
I tried 4 different browsers on 3 computers with the same result.
I also installed 2 different firmware updates (ours was quite old) and just to test it, I reinstalled the latest again, still stuck on the blue screen.
Return to “myQNAPcloud service”
