Stop and disable qnap cloud
How do I stop and disable qnap cloud? I do not use it, and don't plan to, and don't want to be vulnerable to anything.
Re: Stop and disable qnap cloud
Go into the myQNAPcloud app and turn off all the switches and untick all the boxes and uninstall/remove anything (myQNAPcloud Link, SSL certificate) that can be uninstalled or removed if applicable, going down the list of configuration panels on the right one by one (Auto Router Configuration, My DDNS, Publish Services, and so on...). As the final step, sign off your QNAP ID if it's currently signed in.
For additional security, you should want to disable UPnP on your internet router if you don't need it.
