Hello team,
does anyone have myqnapcloud link 1.1.88? please..
I can't download it from app store.
Thanks for helping me
Y.H
myqnapcloud Link 1.1.88
Re: myqnapcloud Link 1.1.88
Same here, whats going on?
I try to go to control manual to enable my "Web server" option, but it ask me to update my firmware , but i am already on the latest QTS 4.2.6
TS-239 Pro owner.
TS-239 Pro owner.
probably not available for old units anymore
contact qnap for confirmation
- spile
- Been there, done that
What was the response from Qnap when you opened a call?Velvet World wrote: ↑Tue Jun 01, 2021 5:36 pm Same here, whats going on?
TS-239 Pro owner.
Same to me, could someone please upload qpkg file, that would help me a lot.
I would need the x86 Version "myQNAPcloud Link 1.1.88"
Filename: CloudLink_1.1.88_20181025_x86.qpkg
Broken-Link: https://download.qnap.com/QPKG/CloudLin ... 25_x86.zip
Response from QNAP support:
Thank you for your reply.
I have feedback from our Product Manager, the myqnapcloud link application for QTS FW 4.3.3 and below was removed from the App Center due to security risk.
There is ongoing security enhancement in the myqnapcloud link for QTS FW 4.3.3 to FW 4.3.6 but currently on testing.
Unfortunately, your NAS latest FW is 4.2.6 EOL version, and the myqnapcloud link application for the EOL NAS will be not available.
Our Product Manager also confirm that there will be no available myqapcloud LInk for the FW QTS 4.2.6 and below.
I am sorry for this trouble and we can only recommend is to use a new NAS.
Thank you for your time and support.
Thank you Wozxyz for your update and information.
So is there a way to connect to our NAS remotely without cloudlink?
1. Does the Qnapcloud has to be used with cloudlink? or is there are route around it to use Qnapcloud without cloudlink? i.e. openvpn?
2. Or simply shall i ask , what is the best remote connection to Qnap NAS with FW QTS 4.2.6 ?
3. Open VPN for Qnap NAS and Open VPN for Mac (I am a mac user) , is a totoally different concept right? I am so confused with 1. OpenVPN setting with QTS 2. portforwarding with router 3. tunnelblick for MAC 4. openvpc.net , since most material only cover QVPN now, which QTS 4.2.6 doesn't has. I wish a can find a remote access setup walkthrough for QTS FW 4.2.6
Thanks again.
Thanks again.
VPN..with the server on your router or other appliances(firewall/raspi/etc) ... it is very easy to setup and use
there is a myriad of guides online
- spile
You can implement a vpn server on some routers or another device like a Raspberry Pi. Securing your NAS does not mean you have to install the vpn on the NAS itself.Velvet World wrote: ↑Fri Jun 04, 2021 10:31 am 3. Open VPN for Qnap NAS and Open VPN for Mac (I am a mac user) , is a totoally different concept right? I am so confused with 1. OpenVPN setting with QTS 2. portforwarding with router 3. tunnelblick for MAC 4. openvpc.net , since most material only cover QVPN now, which QTS 4.2.6 doesn't has. I wish a can find a remote access setup walkthrough for QTS FW 4.2.6
There is a download link for ES Version of the myQNAPcloud Link 1.1.88 x86 version in the german forum
https://forum.qnapclub.de/thread/57924- ... post404175
