Recently, I noticed an extreme number of events in the QUFirewall in which external addresses are trying to get into my NAS. What tipped me onto something happening is my personal account on the NAS was disabled due to the number of failed attempts to login (my account is not the 'admin' account).
So, before anyone asks ...
- yes, I know the firewall is doing it's thing by keeping the bad guys out of my server
- yes, my password is complex (24 chars with a mix of every type)
- yes, my router is secured and I've been trying to block them there
- no, they haven't attacked anything else on my network
What bothers me most is how much external traffic is making it into my network. Not cool. Which is why I'm troubling shooting.
What stopped the attacks is to turn off myQnapCloud access on my NAS. Given the pandemic, I'm not using it anyways. However ... to me it appears there's a security problem on the outside of myqnapcloud ... not cool!
any thoughts?
Thanks!
I'm being attacked ...
Re: I'm being attacked ...
you must have missed all of these
https://www.bleepingcomputer.com/news/s ... s-devices/
https://www.bleepingcomputer.com/news/s ... p-devices/
viewtopic.php?f=45&t=160849
Never ever expose your NAS directly to WAN, no long password or crappy firewall is helping you here. (exploits)
Sometimes even QNAP even realizes this
https://blog.qnap.com/nas-internet-connect-en/
But then they forget about it again
https://www.qnap.com/en-us/news/2021/qn ... sd-support
“Secure remote access and comprehensive file management also make the TVS-x72X series ideal for a remote working file center to improve teamwork and productivity.”
- Moogle Stiltzkin
these are the only remote access usages i recommend
- plex port forwarding only (most people say no problem with this to date)
- vpn remote access (you run a vpn server on your router ideally, and a remote user uses a vpn client to connect to you safely over the internet. Not any vpn protocol will do, use openvpn which is the safest vpn to date. wireguard MAY be ok )
https://www.youtube.com/watch?v=PgielyUFGeQ
https://www.youtube.com/watch?v=rtUl7BfCNMY
if what you are doing is exposing your nas by making your qts accessible online just like that, your telling the hackers to scan your available ports, they will detect your qnap (by detecting the common ports), then they will test if you are running an outdated QTS by using known vulnerabilities, and thats when you get hit. OR even if you do update your qts, you could still get hit by a zero day vulnerability. strong password don't save you from that and 2fa don't save you from vulnerabilities.
tbh instead of QUFirewall, i rather rely on pfsense router firewall and pfblocker running on router for such thing. i'd use it in conjunction with a VPN if the intent is remote access.
here is an example of QNAP qts searchable and accessible from the internet for the qts web access default 8080
https://www.shodan.io/search?query=qnap
DO NOT DO THIS! this is what we meant when not to expose your qnap online in such a manner o-O;
Use a vpn if you need remote access to the QNAP.
and also NEVER use UPNP on your router or any of your devices (although it will all require that your router upnp feature be enabled for them to work to begin with). It automates port forwarding which is a huge risk. Any port forwarding needed e.g. plex and vpn, should be set manually.
better yet, if you do not need remote access, then don't port forward at all to begin with. By default router firewalls such as pfsense are safe at default settings. However you are still required to update your router for the security patches (some people don't realize this)
and other reminders, make sure to regularly UPDATE your router, your qnaps, your client devices on your network e.g. pcs, smart tv, smartphones, wireless access points etc
also keep backups (this protects you from many case scenarios)
https://www.reddit.com/r/qnap/comments/ ... _a_backup/
Last edited by Moogle Stiltzkin on Thu Jun 10, 2021 2:28 pm, edited 2 times in total.
NAS
Network
Resources
Network
Resources
I noticed something similar on my NAS, I put a stop to it by configuring the option under security "Allow connections from the list only" and specifying the client IPs that are allowed to connect to it.
Don't need any enternal IPs to have access to it and if I need to admin the NAS I do it from my LAN not from outside (wan)
disable upnp and remove port forwards(both on router)...why expose your nas if you are not accessing it ?
