Hi to all,
I've a problem with my QNAP TS-459 Pro+ and the myqnapcloud service.
For at least two weeks my QNAP is not connected to the myqnapcloud, but the connection with the DDNS works correctly.
I've tried to reconnect, disable/enable the service, reboot the QNAP and the router with no luck.
Any suggestion?
Thank you.
Error during myqnapcloud connection
Re: Error during myqnapcloud connection
Qnapcloud = Port forwarded (very Dangerous!) ?
or
QnapCloudlink = Tunneled (discontinued for old NAS like yours) ?
or
Thank you
Thank you
I think the NAS needs to support 4.4.2 or higher to download the latest version of cloudlink
https://www.qnap.com/en/app_center/con_ ... =14&os=qts
Setup a VPN then to access your NAS from WAN.. easy and secure
I already do.
I was only using myqnapcloud to share something with friends.
I'll use some another cloud service.
Thank you
Thank you
I just ran into a similar issue with a QNAP TS-459 Pro II with QTS 4.2.6. myQnapcloud Link was working great until about 2 weeks ago. I was a regular user of myQnapcloud and even purchased the SSL certificate though them. Am I to understand that my hardware / firmware version has basically been taken out of long term support?
The ssl cert should not be needed on cloudlink connections as it's tunneled via a qnak qlink.to domain
Anyways..any complaints should be directed towards qnap
