QuWAN vRouter Edition Question and info please!!
Post your questions about myQNAPcloud service here.
ricky89
Post by ricky89 »
Hi!
I would like to subscribe to QuWAN vRouter Edition!
My questions are as follows:
1) is everything on the cloud
2) When I activate the virtual router can I also surf the internet? Can I also create a website?
3) Does it work on Esxi version 7 and 6.7 does not work?
4) How do I install this software on Esxi? Do you have a manual? Where can I find a PDF manual?
5) I'm away from home and I'm using my laptop with 4G LTE connectivity, it's ok because everything is in the cloud and so I'm not working with LTE connectivity, it's like I'm subscribing to an instance.
6) I would like to try this software but including the virtual router will there be a firewall and VPN?
7) I would like all the information and manuals in PDF on how to install the software virtual router cloud on Esxi etc... .
Thank you and waiting for answers.
Translated with www.DeepL.com/Translator (free version)
dolbyman
Re: QuWAN vRouter Edition Question and info please!!
Post by dolbyman »
Best to open a ticket with QNAP, doubt anyone here is using that software ...(user forum)
ricky89
Post by ricky89 »
Thank you for your reply!
Return to “myQNAPcloud service”
