The domain assigned to my device does not work.
DeviceName.qnapmycloud.com
Smart url fetaures works as i can connect with smart url.
http://qlink.to/mydevicename does work.
What do i have to do to make this link to work?DeviceName.qnapmycloud.com
Thanks...
myqnapcloud domain doesn't work.
Re: myqnapcloud domain doesn't work.
"Does not work" is not very useful. If you "ping" the domain name, does it return your current WAN IP? Have you looked in the logs for errors? What does the status page show? What are you trying to access "behind" you router? You should have port forwarding and UPnP disabled (see ransomware threads), so what are you trying to access?
