When I log into myQNAPcloud, my NAS (TS-412) has the yellow clock indicator that says it has not updated in over 24 hours. This makes sense, because I recently moved. However, I can't figure out how to log into it.
it is plugged in, green lights on all the drives and green/amber lights on the NICs show that they are plugged in and working.
My router (Verizon Fios G3100) network panel shows my NAS name connected via ethernet, and has two IP addresses associated with it (192.168.1.154 & 192.168.1.155). I can ping either of those IPs and get a response back.
However, my web browser times out when trying to connect to either IP. Also, nmap scans show "filtered" on ports 22, 80, & 443.
QNAP Finder Pro on my Windows machine says there's no NAS on my home network. (Tried with QNAP versions 6.6.6 and 7.8.1).
Qmanager app for Android also says there's no NAS on my network.
What else can I try to log into my NAS?
No access after move
Re: No access after move
Stop using myqnapcloud asap!
See the Deadbolt link in my signature and avoid to be a victim of malware!
If you have moved, did your clients get new IP adresses and did you setup IP security at NAS so that the client IPs are blocked?
A 3s reset can help you to gain login again.
The 3s reset resets admin password to default, at your old NAS to "admin" and IP settings to default DHCP.
Regards
Regards
Deadbolt - READ 1st post!!!
Deadbolt - information
VPN=VPN? No!
www.raidisnotabackup.com
VPN=VPN? No!
I solved my issue by remembering that I had a different subnet in use at my old residence. Once I remembered what subnet I had been using and changed my local network settings, I was able to access my machine.
And all warnings about exposing your NAS ignored?...Criminals made millions of bucks from deadbolt alone..and they will continue to rake in the cash
