I deleted the NAS (TS410) from "My Devices" in MyQNAPcloud and I want to add it again. When I try to log out to repeat the procedure I get the following error:
"Failed to sign out. The server may be busy. Please try again later".
It is like the NAS has not received the update that it has been removed.
Failed to sign out QTS 4.2.6
Re: Failed to sign out QTS 4.2.6
I just want to have a DDNS
read the thread what happens when you expose your NAS to WAN..no matter if with DDNS or not
So I should not use myqnapcloud at all?
disable upnp and port forwards in your router
