I set up a new TS-269 PRO. I can access it from local network. I setup the WEB server and the MYSQL server I can access both from local lan. The problem start when I try to connect to it from external network. (i.e. from another computer connected via another router to another ISP). I follow the steps in the documentation. Enabled the VPN installed the the MyCloudNAS application that accessed my router and performed the port forwarding. I Created the myQNAPCloud account. When I try to access the NAS from outside I can see it at the cloud and it shows the device and all the shared functions. But when I try to connect to one of them I get a waiting for response forever.
I will appreciate if someone can help me solve this problem.
Problem accessing my TS-269 PRO from remote
- pwilson
Re: Problem accessing my TS-269 PRO from remote
Which VPN solution are you attempting to use?LevShlomo wrote:I set up a new TS-269 PRO. I can access it from local network. I setup the WEB server and the MYSQL server I can access both from local lan. The problem start when I try to connect to it from external network. (i.e. from another computer connected via another router to another ISP). I follow the steps in the documentation. Enabled the VPN installed the the MyCloudNAS application that accessed my router and performed the port forwarding. I Created the myQNAPCloud account. When I try to access the NAS from outside I can see it at the cloud and it shows the device and all the shared functions. But when I try to connect to one of them I get a waiting for response forever.
If you are using the insecure PPTP VPN, you can access it at 10.0.0.1.
If you are using the OpenVPN solution it is at 10.8.0.1.
I use OpenVPN here:
Once you have connected via the undisclosed VPN solution, you simply access the NAS at it's VPN address.
Patrick M. Wilson
Victoria, BC Canada
