I have a QNAP TS-459 Pro II.
I am testing it for potential use at a customers site as a Dropbox replacement. I have "myQNAPcloud" setup and Qfile on my iphone 5s. I have the following issues.
* Qfile takes too long to connect to myQNAPcloud... 1-2 minutes.
* Once Qfile connects I can browse my folders. However, it will randomly loose connection and show the following error...
"Qsync service does not enable"
* If I click refresh on Qfile the files sync again and I am able to see the folders.
* I have tired to upload a file from my phone but it will not send.
I realize this is all beta... I wanted to see if anyone else has experienced this.
Qsync on my workstations performs flawlessly.
Qfile - iPhone - Slowness and Error
- schumaku
Re: Qfile - iPhone - Slowness and Error
Do you know on how Qfile does connect to the NAS? Is the NAS reachable using i.e. a port forward on https://[yourname].myqnapcloud.com/ or does the connection fall-back to CloudLink which does take much more time for the initial connections, and some more for each action?
Regards,
-Kurt.
Regards,
-Kurt.
I have the same issue, I tried to use all the ways to connect but all failed, I am in my home LAN with the NAS.
my type is TS-420, version is the latest 4.1.x
