Can't acces Qnapcloud
UPnP is on on both of the routers. DHCP is on on both. NAS is connected to second (older working Linksys E2500). When i go into myqnapcloud.com to check added devices i can see real internal IP of the router, but there is no acces to it.
Here is screenshot of NSlookup and router info in qnapcloud.com I have attached the screenshot. Please tell me what to check. I have no idea about how ports should work if i have 2 routers.
- doktornotor
Re: Can't acces Qnapcloud
You should NOT have two routers on your network. You most certainly should turn off DHCP on the second router, avoid using its WAN port and in general only let it act as a dumb switch.
I'm gone from this forum till QNAP stop wasting volunteers' time. Get help from QNAP helpdesk instead.
Warning: offensive signature and materials damaging QNAP reputation follow:
QNAP's FW security issues
QNAP's hardware compatibility list madness
QNAP's new logo competition
Dear QNAP, kindly fire your clueless incompetent forum "admin" And while at it, don't forget the webmaster!
If i switch off DHCP on the second router(Linksys), UPNP settings should apply from the first one?
Off-topic: I was using Linksys E2500 only before, but after chaging ISP it was not able to handle all 100Mbits from ISP, so i took a cheap TP-Link that can handle ISP'S L2TP at 100Mbits, but its wifi module is crap, disconnecting every 1-2 hours. So i left TP-Link like a "cable modem" and using Cisco to distribute all internet to LAN and Wi-Fi devices.
- doktornotor
It was my fault as usual. You was right. Just pluged my second router as a simple switch (without DHCP) and all works fine!
Thank you very much!
- pwilson
I have 5 Routers on my network. (Of course 4 of them are configured as WAP's).doktornotor wrote:You should NOT have two routers on your network. You most certainly should turn off DHCP on the second router, avoid using its WAN port and in general only let it act as a dumb switch.
Patrick M. Wilson
Victoria, BC Canada
