Virtualization station no longer working after update?!?
- Pistolprinsen
I updated the virtualization yeaterday, but now it no longer starts when I click the icon on the QTS.
All I get it: "Page not found or the web server is currently unavailable. Please contact the website administrator for help."
Tried restarting the server, and everything!
What do I do???
What do I do???
Re: Virtualization station no longer working after update?!?
I've got the same issue. The web gui won't load and gives an "Error" as if the webserver is the issue. I've restarted the webserver, reinstalled VS, rebooted, etc. Even going to the link directly via: http://NAS_IP:8088/login/ doesn't work. According to App Center VS is installed and running.
- Pistolprinsen
I've done all the same things - nothing seems to work!
QNAP: Time to take action - there's something wrong with your update!
- Toxic17
QNAP Tech Support do not monitor these forums. if you have an issue report it via the helpdesk app, or https://helpdesk.qnap.com/index.php?/Tickets/SubmitPistolprinsen wrote:QNAP: Time to take action - there's something wrong with your update!
this is the only way issues will become fixed.
Regards Simon
Qnap Downloads
MyQNap.Org Repository
Qnap Downloads
I had the same issue, this is how I fixed it:
For reference I have my System Port set to 3000 and my HTTPS port set to 3001.
1. Log into the interface
2. Control Panel >> General Settings >> System Administration >> System Port
3. Changed my "System Port" from 3000 => 3500
4. Change my HTTPS System port from 3001 => 3501
5. Apply
6. Re-login on new port http://ip:3500
7. Change Port settings back to original (3000 & 3001)
8. Apply
9. Re-login
10. Virtualization management page now works.
Hope that helps you.
5. Apply
8. Apply
9. Re-login
Thanks Vadakill.
Changing the ports to and from a different value worked for me too! Strange..
Changing port doesn't work on me. Is there other solution, please.
- papampi
Try with other systems and browsers
It doesnt work on my ubuntu via QTS web nor does it work with ip:port no matter what browser I use.
It also has problem on my wife windows 10 with latest chrome, but works ok with microsoft edge and firefox
also works on my Android tablet with chrome...
Models: TVS-863, HS-251
قیمت فروش پیچ و مهره
- Hot Sauce
It is browser related.. FIrefox I did not have any luck, but I was able to use in Edge (Blah!) It is a display issue on my end and could be related to this notebook I am using. Once the default Virtualization page pops up you can't see the finish button on the very bottom. Once this finished button is pushed you can move on to the next page.. TRy another browser (Edge, IE, Chrome, etc)
TS-251 w/ 16 gb of RAM
I tried different browsers to no avail.
Same thing here. Changing ports didn't help. I've solved turning off the app and re-opening it. Looks like a little bug in the update
