Virtualization station will not start
Locked
OBear
Post by OBear »
Hi all,
I have a TS669 Pro and i just installed QTS 4.3.3 beta as i saw it could support the latest (also beta) version of QVS (3.0.2096_20170213_x86_64).
After installing new firmware on QNAP and rebooting, everything seemed fine, i installed QVS and it installed successfully however it did not start.
rebooted several times and reinstalled a few more and to no avail.
I checked the logs in /share/CACHEDEV1_DATA/.qpkg/QKVM/var/log
and qvsd.err.log had this to say
insmod: can't insert '/lib/modules/3.4.6/kvm.ko': No such file or directory
insmod: can't insert '/lib/modules/3.4.6/virtio.ko': No such file or directory
insmod: can't insert '/lib/modules/3.4.6/virtio_ring.ko': No such file or directory
insmod: can't insert '/lib/modules/3.4.6/virtio-rng.ko': No such file or directory
insmod: can't insert '/lib/modules/3.4.6/virtio_balloon.ko': No such file or directory
insmod: can't insert '/lib/modules/3.4.6/virtio_blk.ko': No such file or directory
insmod: can't insert '/lib/modules/3.4.6/virtio_console.ko': No such file or directory
insmod: can't insert '/lib/modules/3.4.6/virtio_mmio.ko': No such file or directory
insmod: can't insert '/lib/modules/3.4.6/virtio_net.ko': No such file or directory
insmod: can't insert '/lib/modules/3.4.6/virtio_pci.ko': No such file or directory
insmod: can't insert '/lib/modules/3.4.6/virtio_scsi.ko': No such file or directory
insmod: can't insert '/lib/modules/3.4.6/vringh.ko': No such file or directory
insmod: can't insert '/lib/modules/3.4.6/tun.ko': No such file or directory
insmod: can't insert '/lib/modules/3.4.6/macvlan.ko': No such file or directory
insmod: can't insert '/lib/modules/3.4.6/macvtap.ko': No such file or directory
insmod: can't insert '/lib/modules/3.4.6/vhost.ko': No such file or directory
insmod: can't insert '/lib/modules/3.4.6/vhost_net.ko': No such file or directory
insmod: can't insert '/lib/modules/3.4.6/vhost_scsi.ko': No such file or directory
insmod: can't insert '/lib/modules/3.4.6/vfio.ko': No such file or directory
insmod: can't insert '/lib/modules/3.4.6/vfio_virqfd.ko': No such file or directory
insmod: can't insert '/lib/modules/3.4.6/vfio-pci.ko': No such file or directory
insmod: can't insert '/lib/modules/3.4.6/vfio_iommu_type1.ko': No such file or directory
/share/CACHEDEV1_DATA/.qpkg/QKVM/usr/etc/qvsd.d/44-preload/01-module: line 110: /sys/module/vfio_iommu_type1/parameters/allow_unsafe_interrupts: No such file or directory
/share/CACHEDEV1_DATA/.qpkg/QKVM/usr/etc/qvsd.d/44-preload/01-module: line 111: /sys/module/kvm/parameters/allow_unsafe_assigned_interrupts: No such file or directory
[module start failure code 1]
i quick search revealed absolutely nothing, so not even sure theres any sort of support for beta software, but figure id try my luck.
from what i can tell its missing a whole bunch of dependencies but not sure how to even go about getting them.
Any help would be most welcome
thero76
Re: Virtualization station will not start
Post by thero76 »
Same here!
Install all ok put start not work.
michal.slowinski
Post by michal.slowinski »
Today after upgrade to QTS 4.3.3, Virtualization station dont work.
I only see "Infomracja ogólna" nothing more, i need this virtualization station badly.
Trexx
Ask me anything
Post by Trexx »
michal.slowinski wrote:Today after upgrade to QTS 4.3.3, Virtualization station dont work.
What happens if you change the QTS language to English? Have you tried running in a different browser (Chrome seems to work most consistently)?
Paul
UPS: CP AVR1350
michal.slowinski
Trexx ty for hint.
Its web browser, on firefox it's work on chrome no.
Ty very much.
cattivik39
Post by cattivik39 »
Hi i'm new user and i have the same problem and i don't resolve with firefox : i restarted my qnap but situation is the same : not working. I see only overwiew ! Please help me.
thero76
Post by thero76 »
Hallo @ll
Please back to Topic!!!
The problem is not the accessibility but the start .
@OBear
Have you Network & Virtual Switch ??
cattivik39
Yes I have and have minimum requisite
but not see the next step
cattivik39
ok solved! the apps required an https connection.
Knightro
Post by Knightro »
Even at https, it's not working. With error "The webpage at https://xxxxx.myqnapcloud.com/qvs/?windowId=QKVM& might be temporarily down or it may have moved permanently to a new web address."
Trexx
Ask me anything
Post by Trexx »
first off, access your NAS via local IP address and then from QTS try running VS. Let's start with a simple way of accessing it 1st.
Paul
UPS: CP AVR1350
thero76
Post by thero76 »
@Trexx
THX put this is not the solution to this problem.Please go to the first and Topic "Virtualization station will not start".
Trexx
Ask me anything
Post by Trexx »
thero76 wrote:@Trexx
I was replying to the prior uses post about not being able to access VS via myqnapcloud address. in some cases that can be cause by changing of ports, so wanted to make sure was accessible locally first.
Agreed that neither item was in reference to original post.
Paul
UPS: CP AVR1350
RobHyde
Post by RobHyde »
I was able to get mine to work by connecting to QTS first by IP. Then launch Virtualization Station from QTS. I think it has something to do with the change HTTS ports (or no certificate).
OneCD
Post by OneCD »
Locked
Return to “Virtualization Station”
