VMware SVGA II driver
I have a TS-563 running virtual server 2012 r2. It is working great except that it shows it's using Microsoft Basic Display driver. Looking up the hardware it is actually VMware SVGA II. However I can find no driver for it, and I cannot load VMWare's toolbox, where I believe the driver is located, I think because the QNAP Virtual agent will not start.
Re: VMware SVGA II driver
I am confused. I can load the iso you mentioned. The guest agent in it still will not run (will not start). The VFD's I have no idea how to use. I admit I'm a bit new to this. I already have the virtual network and drive drivers working.
so if you install the guest addon under
guest-agent\qemu-ga-x64.msi
nothing happens ?
nothing happens ?
- Trexx
VS has nothing to do with VMware guest/tools. You will want to unlstinall any VMware tools/drivers.
Paul
UPS: CP AVR1350
UPS: CP AVR1350
I have no vmware tools or anything else installed. Just the virtual Drivers provided by qnap. Just searching for the virtual video driver..
Yes guest agent installs but ervice will not start. Got network vm driver and vm scsi driver installed. No video driver.
- Trexx
You need to install the QXL driver and switch you VS config to use QXL for video mode.
Paul
UPS: CP AVR1350
UPS: CP AVR1350
I got the hardware name by looking up the hardware I'd under video in device manager. Vmware svaga 11 .how do I change to qxl mode? Didnt see it as an option under vmhardware on qnap.
Still looking for answer on QXL Mode?
- Trexx
Which version of VS are you running? Which QTS firmware/build version are you running? Did you create the VM from scratch in VS or did you import it?
Please post a screenshot of your VM display setting as the VMware driver had to have been installed via VMware tools at one point.
Paul
UPS: CP AVR1350
UPS: CP AVR1350
Virtualization Station
Version : 2.2
Build Version : 5633
Build Date : 20170320
Created from scratch Using Create VM with Windows Server 2012 Settings
- Trexx
Ok... so VMVGA is not the same as VMware VGA, so the screenshot helped.
QXL is only available on VS 3.0 Beta I believe, which is based on a newer QEMU version. I don't remember if that requires QTS 4.3.x to run.
I would definitely recommend going to the newer VS 3.x version, but shutdown your VM and make a backup before upgrading VS.
Paul
UPS: CP AVR1350
UPS: CP AVR1350
Thank you for helping me figure this out. This system is going into a production environment next week, and not ready to try out beta software on it. I will let you know once it's released and I have some downtime if that was the issue!
- Trexx
No problem, glad we got some clarity around the issue.
Paul
UPS: CP AVR1350
UPS: CP AVR1350
