I have a TVS-671 4Gb RAM, on QTS 4.3.3, virtualizationstation 3. I create a new VM using Windows10 iso, but when i try to start it i get
"Error an exception has occured (2)." then the whole NAS locks and only solution is a hard reboot!
Anyone seen this before?
i know my router Does NOT support UPnP, do i need to forward ports?
thanks
Creating New VM error
- Trexx
Re: Creating New VM error
I would check you CPU, HDD, and Display VM's settings to start with. Did you install the VM Guest Tools?
I have a Win10 VM running just fine on the latest VS 3.x
Paul
UPS: CP AVR1350
UPS: CP AVR1350
Hi Trexx, yes allocated 2 cores, memory 2GB, did not see setting for display!, i thought Guest tools could only be installed once windows installation finished?
- Trexx
So are you getting the error DURING the install, or after the install?mbs77 wrote:Hi Trexx, yes allocated 2 cores, memory 2GB, did not see setting for display!, i thought Guest tools could only be installed once windows installation finished?
Paul
UPS: CP AVR1350
UPS: CP AVR1350
During the install
Confirming exactly the same issue, trying to setup Ubuntu VM . See attached screenshot
I updated to the latest QNAP 4.3, rebooted several times. Made sure everything is writable.
I have the same issue after the lattes update, all my current VMs work but I am not able to create new ones I keep getting the error 2 once I hit start to turn on the machine and begin the installation. Anyone figure out anything yet?
