Android x86 on virtualization station
Hello!
I have TS451+-8G and I am wondering if its possible to download Android-x86 7.1, ISO file (on www.android-x86.org) and import it on Virtualization station and run it? Or has it to be Android-x86 4.4-RC1 which is listed in the support OS list?
Thanks for reply!
Thanks for reply!
Re: Android x86 on virtualization station
why not just try it?
Im going to try it I just bought the nas today so it will be delivered this week. Just asked if anybody know?
- Moogle Stiltzkin
gratzpaullovdahl wrote:Im going to try it I just bought the nas today so it will be delivered this week. Just asked if anybody know?
in virtual station there is an android x86 in the OS selection. i haven't tried it myself but would seem it could do android.
in the documentation also says can do android
https://www.qnap.com/solution/virtualiz ... ion/en-us/
somebody also asked a similar question to you here
viewtopic.php?t=129958
NAS
Network
Resources
Network
Resources
Hey - did you get it installed? I am looking for a similar config and wanted to see what you explored and its success?paullovdahl wrote:Im going to try it I just bought the nas today so it will be delivered this week. Just asked if anybody know?
I've tried to install two versions of Android-x86:
1. CM-x86-14.1-rc1 http://www.android-x86.org/releases/rel ... 6-14-1-rc1
2. Android-x86 7.1-rc2 (Nougat-x86) http://www.android-x86.org/releases/releasenote-7-1-rc2
#1 installed but would not start. It hangs at the green curve startup screen and never boots.
#2 installs successfully and boots. However the mouse pointer doesn't work in the Remote Console (VNC) so you can't do anything with it.
Update: After playing with this a bit more the mouse is broken but can work if you single click and hold, then you can move the pointer around. Unfortunately, Virtualization Station doesn't emulate a PS/2 mouse and there's no setting to select the pointer type, like there is in the VirtualBox stand-alone application. Of less concern but still not great is the native resolution of VGA seems to be 640x480, and I can't find any configuration in Android or on the VM to change that to a higher res. So all in all, useless.
In other words, VM station is not compatible with Androidx86.
- Moogle Stiltzkin
imclumzy wrote:I've tried to install two versions of Android-x86:
just double checked what you already confirmed.
i tested the nougat. got the mouse to work kinda, but barely.
definitely could be improved upon put it that way. you may need to create helpdesk ticket to suggest they improve upon this, to get mouse working via VNC.
NAS
Network
Resources
Network
Resources
Even if the mouse worked I don’t see much practical use of an android VM that has a 640x480 resolution. That would need to be fixed too for this to be a viable VM.
- ArturPhk
Have you tried using HDMI output and a physical keyboard\mouse connected to QNAPs USB port?
- Easy as a breeze
I just ran Android-x86 8.1-rc1 (Oreo-x86) live CD [rc2 should be available but the mirrors do not yet contain it]. At least there the keyboard (US mode, no localized chars) and mouse work fine. Anyhow I have no practical use case for this VM right now.
- ArturPhk
Nice. I tried the same ISO with on-disk install instead of live CD, but it didn't worked ok.
Have you tried any game with your VM? I'm wondering if HW acceleration is available for GPU. I'm using a 251+ here.
Cheers
Hey guys, any new feed about Android and Virtualization Station?
I wonder if is there any light version of Android would work as vm on qnap nas server only just for use Google Assistant to work on place with my iot devices.
As a normal android device, you know.
I bought small mic and want to use it thru mic port in my Ts 263Be, to say "Hello Google" directly to him.
Any ideas how to fix it?
- ArturPhk
hi Mario, welcome.
No progress here, tbh didn't try any further. By a nest mini for 30€ and you'll have your use-case operational!
