After discussing, we confirm that NVME SSD now still not totally support as storage like HDD and SSD.
We recommend that NVME SSD only used as SSD cache.
This will be fixed on Firmware 4.4.0.0606 build20180619
NVMe Storage for VM not fully supported?
I have a QNAP TS-453Be with QM2-2P10G1T and 2x PLEXTOR PX-256M8. I created a Windows 7 VM and placed on my NVMe storage and the VM would stop responding and Virtualization Station would lock up. I opened a ticket and after a month of investigation, below was the response. Anyone else having similar issues?
Re: NVMe Storage for VM not fully supported?
Why did you choose this NVMe card for a TS-453Be?
This NAS will not use the speed that the NVMe drive have, as the PCIe-Port is too slow.
The normal SATA M.2 card is enough and this works together with the Virtualization Station.
I just realized that I never responded to your post, iMactouch.
I considered the SATA version of the card (QM2-2S10G1T), which for me was about the same price on Amazon, B&HPhoto, etc. I opted against it because I like the Plextor M8Pe 256GB drives, which are only available in NVMe. The Plextor M8Pe have the best endurance for that price at 384 Terra-byte Writes (TBW), compared to Samsung EVO 970 which is 150TBW. The Samsung 970 Pro, which has similar endurance numbers, doesn't come in 256GB size, so is more expensive at 512GB.
Also, the SATA interface is limited to 6Gbps -> 750MB/s, so using NVMe, even bottlenecked by the PCIe 2.0x2, will be a 33% bandwidth increase at 1000MB/s. The Virtual Machines that I'll put on the M.2 SSD will be able to use the extra bandwidth.
Dang...I came across this thread by searching the same problem. Although I have a TS-1277, my VMs are hosted on the NVMe M2s and the VMs/VS stops responding randomly.
As the OP mentioned, the VMs greatly benefit from the NVMe.
I think I will be able to remove my SSDs as cache, re-initialize as storage for my VMs. Being new to QNAP and VS, I guess I simply move the VM folders to the new volume and then import them back into VS?
Production NAS: TS-1277-1600-64G FW: 4.3.5.x
RAM: 64GB QNAP
OS/Apps: 2 x Samsung 860 Evo 1TB M.2s (RAID-1)
Cache: 2 x Samsung 860 Evo 250GB 2.5 SSD (RAID-1)
VMs: 2 x Samsung 970 Evo 1TB M.2s NVMe (RAID-1)
Data: 6 x 12TB Seagate Enterprise Helium (RAID-6)
Network: QNAP Dual-Port 10GbE SFP+
UPS: APC Smart UPS 1500C
Media Boxes: AppleTV 4, Nvidia ShieldTV Pro, Roku Sticks
Backup NAS: TS-873-4G FW: 4.3.6.x
RAM: 16GB Kingston HyperX Fury Kit DDR4-2666
RAM: 64GB QNAP
- Trexx
Open Helpdesk tickets with QNAP. I have VM's running fine on my sata SSD volume, so not sure why NVMe is causing it. Sounds like HW related issue.
Paul
UPS: CP AVR1350
UPS: CP AVR1350
Help desk says that SATA should work fine, but that there is an issue with NVMe and virtual machines that should be corrected in version 4.4.0. Don't know if it's a virtual machine app issue or a NAS operating system issue that VMs are affected by. I've been waiting almost 4 months for a fix to this!
- Trexx
If it is QTS 4.4.0, could be some either/both. QTS 4.4.0 will have new kernel baseline, which either solves the problem, or is needed to facilitate a VS core update.321liftoff wrote: ↑Wed Dec 19, 2018 3:33 am Help desk says that SATA should work fine, but that there is an issue with NVMe and virtual machines that should be corrected in version 4.4.0. Don't know if it's a virtual machine app issue or a NAS operating system issue that VMs are affected by. I've been waiting almost 4 months for a fix to this!
Paul
UPS: CP AVR1350
UPS: CP AVR1350
Hope in QTS 4.4.0 this feature come....
I downloaded QTS 4.4.1 beta. I'm running Virtualization Station 3.2.355 and Windows 10 as a guest OS, and performance seems to be much better.
I have a QNAP TS-453Be with QM2-2P10G1T and 2x PLEXTOR PX-256M8 in RAID 1 static volume with 20% Over-provisioning. Below are some benchmark results that are lower that I would have expected:
- 786.44 MB/s sequential read (1M) raid
- 757.40 MB/s sequential read (1M) filesystem
- 414.6MB/s sequential read (8k)
- 335.9MB/s sequential write (32k)
- 600.4MB/s random read (8k)
- 343.2MB/s random write (64k)
- 485.8MB/s random read/write (16k)
[/share/CACHEDEV2_DATA/SSDVirtualMachine] # qcli_storage -T
fio test command for physical disk: /sbin/fio --filename=test_device --direct=1 --rw=read --bs=1M --runtime=15 --name=test-read --ioengine=libaio --iodepth=32 &>/tmp/qcli_storage.log
fio test command for RAID: /sbin/fio --filename=test_device --direct=0 --rw=read --bs=1M --runtime=15 --name=test-read --ioengine=libaio --iodepth=32 &>/tmp/qcli_storage.log
Start testing!
Performance test is finished 100.000%...
Enclosure Port Sys_Name Throughput RAID RAID_Type RAID_Throughput Pool
NAS_HOST 1 /dev/sdc 130.27 MB/s /dev/md1 RAID 6 68.40 MB/s 1
NAS_HOST 2 /dev/sdd 122.66 MB/s /dev/md1 RAID 6 68.40 MB/s 1
NAS_HOST 3 /dev/sda 147.62 MB/s /dev/md1 RAID 6 68.40 MB/s 1
NAS_HOST 4 /dev/sdb 120.33 MB/s /dev/md1 RAID 6 68.40 MB/s 1
NAS_HOST P1-1 /dev/nvme1n1 772.84 MB/s /dev/md2 RAID 1 786.44 MB/s 288
NAS_HOST P1-2 /dev/nvme0n1 769.51 MB/s /dev/md2 RAID 1 786.44 MB/s 288
[/share/CACHEDEV2_DATA/SSDVirtualMachine] # qcli_storage -t
fio test command for LV layer: /sbin/fio --filename=test_device --direct=0 --rw=read --bs=1M --runtime=15 --name=test-read --ioengine=libaio --iodepth=32 &>/tmp/qcli_storage.log
fio test command for File system: /sbin/fio --filename=test_device/qcli_storage --direct=0 --rw=read --bs=1M --runtime=15 --name=test-read --ioengine=libaio --iodepth=32 --size=128m &>/tmp/qcli_storage.log
Start testing!
VolID VolName Pool Mapping_Name Throughput Mount_Path FS_Throughput
1 DataVol1 1 /dev/mapper/cachedev1 68.27 MB/s /share/CACHEDEV1_DATA 69.60 MB/s
2 DataVol2 288 /dev/mapper/cachedev2 786.95 MB/s /share/CACHEDEV2_DATA 757.40 MB/s
[/share/CACHEDEV2_DATA/SSDVirtualMachine] # fio --name=seqread --rw=read --direct=1 --ioengine=libaio --bs=8k --numjobs=8 --size=1G --runtime=600 --group_reporting
seqread: (g=0): rw=read, bs=8K-8K/8K-8K/8K-8K, ioengine=libaio, iodepth=1
fio-2.2.10
Starting 8 processes
Jobs: 2 (f=1): [_(5),R(2),_(1)] [100.0% done] [414.6MB/0KB/0KB /s] [53.7K/0/0 iops] [eta 00m:00s]
seqread: (groupid=0, jobs=8): err= 0: pid=26812: Sun Jun 2 15:45:12 2019
read : io=8192.0MB, bw=469555KB/s, iops=58694, runt= 17865msec
slat (usec): min=12, max=17841, avg=19.94, stdev=46.99
clat (usec): min=1, max=17789, avg=111.92, stdev=119.45
lat (usec): min=65, max=17955, avg=132.56, stdev=129.08
clat percentiles (usec):
| 1.00th=[ 57], 5.00th=[ 61], 10.00th=[ 64], 20.00th=[ 73],
| 30.00th=[ 89], 40.00th=[ 101], 50.00th=[ 108], 60.00th=[ 115],
| 70.00th=[ 121], 80.00th=[ 131], 90.00th=[ 149], 95.00th=[ 169],
| 99.00th=[ 241], 99.50th=[ 330], 99.90th=[ 1144], 99.95th=[ 2064],
| 99.99th=[ 5408]
bw (KB /s): min=47088, max=65728, per=12.59%, avg=59128.35, stdev=2720.50
lat (usec) : 2=0.01%, 4=0.15%, 10=0.01%, 20=0.01%, 50=0.17%
lat (usec) : 100=37.64%, 250=61.10%, 500=0.61%, 750=0.13%, 1000=0.05%
lat (msec) : 2=0.06%, 4=0.04%, 10=0.01%, 20=0.01%
cpu : usr=4.57%, sys=17.32%, ctx=1075335, majf=0, minf=232
IO depths : 1=100.0%, 2=0.0%, 4=0.0%, 8=0.0%, 16=0.0%, 32=0.0%, >=64=0.0%
submit : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0%
complete : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0%
issued : total=r=1048576/w=0/d=0, short=r=0/w=0/d=0, drop=r=0/w=0/d=0
latency : target=0, window=0, percentile=100.00%, depth=1
Run status group 0 (all jobs):
READ: io=8192.0MB, aggrb=469555KB/s, minb=469555KB/s, maxb=469555KB/s, mint=17865msec, maxt=17865msec
Disk stats (read/write):
dm-103: ios=1048471/48, merge=0/0, ticks=104363/117, in_queue=105440, util=99.58%, aggrios=1048576/51, aggrmerge=0/0, aggrticks=101825/116, aggrin_queue=103049, aggrutil=99.53%
dm-10: ios=1048576/51, merge=0/0, ticks=101825/116, in_queue=103049, util=99.53%, aggrios=0/0, aggrmerge=0/0, aggrticks=0/0, aggrin_queue=0, aggrutil=0.00%
drbd2: ios=0/0, merge=0/0, ticks=0/0, in_queue=0, util=0.00%, aggrios=1048576/51, aggrmerge=0/0, aggrticks=0/0, aggrin_queue=0, aggrutil=0.00%
md2: ios=1048576/51, merge=0/0, ticks=0/0, in_queue=0, util=0.00%, aggrios=524288/73, aggrmerge=0/1, aggrticks=50365/37, aggrin_queue=35750, aggrutil=95.43%
nvme0n1: ios=550375/73, merge=0/1, ticks=53166/40, in_queue=38503, util=95.43%
nvme1n1: ios=498201/73, merge=0/1, ticks=47565/35, in_queue=32998, util=92.69%
[/share/CACHEDEV2_DATA/SSDVirtualMachine] # fio --name=seqwrite --rw=write --direct=1 --ioengine=libaio --bs=32k --numjobs=4 --size=2G --runtime=600 --group_reporting
seqwrite: (g=0): rw=write, bs=32K-32K/32K-32K/32K-32K, ioengine=libaio, iodepth=1
fio-2.2.10
Starting 4 processes
Jobs: 4 (f=4): [W(4)] [100.0% done] [0KB/335.9MB/0KB /s] [0/10.8K/0 iops] [eta 00m:00s]
seqwrite: (groupid=0, jobs=4): err= 0: pid=30050: Sun Jun 2 15:46:36 2019
write: io=8192.0MB, bw=346479KB/s, iops=10827, runt= 24211msec
slat (usec): min=20, max=24006, avg=44.49, stdev=104.60
clat (usec): min=2, max=15739, avg=318.53, stdev=211.22
lat (usec): min=135, max=24232, avg=363.88, stdev=234.32
| 1.00th=[ 137], 5.00th=[ 199], 10.00th=[ 233], 20.00th=[ 270],
| 30.00th=[ 290], 40.00th=[ 302], 50.00th=[ 314], 60.00th=[ 322],
| 70.00th=[ 330], 80.00th=[ 342], 90.00th=[ 370], 95.00th=[ 394],
| 99.00th=[ 660], 99.50th=[ 1064], 99.90th=[ 3216], 99.95th=[ 4384],
| 99.99th=[ 8096]
bw (KB /s): min=78976, max=92544, per=25.05%, avg=86799.40, stdev=2660.01
lat (usec) : 4=0.01%, 10=0.02%, 20=0.01%, 50=0.01%, 100=0.01%
lat (usec) : 250=13.93%, 500=84.39%, 750=0.78%, 1000=0.29%
lat (msec) : 2=0.31%, 4=0.18%, 10=0.05%, 20=0.01%
cpu : usr=4.74%, sys=11.70%, ctx=267688, majf=0, minf=105
issued : total=r=0/w=262144/d=0, short=r=0/w=0/d=0, drop=r=0/w=0/d=0
WRITE: io=8192.0MB, aggrb=346479KB/s, minb=346479KB/s, maxb=346479KB/s, mint=24211msec, maxt=24211msec
dm-103: ios=2/261677, merge=0/0, ticks=2/82634, in_queue=82773, util=99.37%, aggrios=2/262289, aggrmerge=0/0, aggrticks=2/81936, aggrin_queue=82037, aggrutil=99.19%
dm-10: ios=2/262289, merge=0/0, ticks=2/81936, in_queue=82037, util=99.19%, aggrios=0/0, aggrmerge=0/0, aggrticks=0/0, aggrin_queue=0, aggrutil=0.00%
drbd2: ios=0/0, merge=0/0, ticks=0/0, in_queue=0, util=0.00%, aggrios=2/262289, aggrmerge=0/0, aggrticks=0/0, aggrin_queue=0, aggrutil=0.00%
md2: ios=2/262289, merge=0/0, ticks=0/0, in_queue=0, util=0.00%, aggrios=1/262306, aggrmerge=0/6, aggrticks=1/71645, aggrin_queue=55427, aggrutil=96.11%
nvme0n1: ios=1/262306, merge=0/6, ticks=1/74072, in_queue=57733, util=96.11%
nvme1n1: ios=1/262306, merge=0/6, ticks=1/69218, in_queue=53121, util=95.48%
[/share/CACHEDEV2_DATA/SSDVirtualMachine] # fio --name=randread --rw=randread --direct=1 --ioengine=libaio --bs=8k --numjobs=16 --size=1G --runtime=600 --group_reporting
randread: (g=0): rw=randread, bs=8K-8K/8K-8K/8K-8K, ioengine=libaio, iodepth=1
fio-2.2.10
Starting 16 processes
randread: Laying out IO file(s) (1 file(s) / 1024MB)
Jobs: 9 (f=7): [r(2),_(1),r(1),_(1),r(1),_(1),r(1),_(2),r(1),_(2),r(3)] [100.0% done] [600.4MB/0KB/0KB /s] [76.9K/0/0 iops] [eta 00m:00s]
randread: (groupid=0, jobs=16): err= 0: pid=5820: Sun Jun 2 15:49:13 2019
read : io=16384MB, bw=638864KB/s, iops=79858, runt= 26261msec
slat (usec): min=12, max=33887, avg=23.61, stdev=85.45
clat (usec): min=1, max=22782, avg=168.88, stdev=176.48
lat (usec): min=49, max=33985, avg=193.43, stdev=198.95
| 1.00th=[ 92], 5.00th=[ 107], 10.00th=[ 114], 20.00th=[ 123],
| 30.00th=[ 131], 40.00th=[ 137], 50.00th=[ 145], 60.00th=[ 155],
| 70.00th=[ 167], 80.00th=[ 187], 90.00th=[ 225], 95.00th=[ 274],
| 99.00th=[ 506], 99.50th=[ 772], 99.90th=[ 2416], 99.95th=[ 3536],
| 99.99th=[ 7328]
bw (KB /s): min=27936, max=52992, per=6.32%, avg=40403.89, stdev=3954.79
lat (usec) : 2=0.03%, 4=0.42%, 10=0.03%, 20=0.02%, 50=0.07%
lat (usec) : 100=1.51%, 250=91.16%, 500=5.74%, 750=0.50%, 1000=0.20%
lat (msec) : 2=0.19%, 4=0.10%, 10=0.03%, 20=0.01%, 50=0.01%
cpu : usr=3.39%, sys=11.31%, ctx=2231529, majf=0, minf=520
issued : total=r=2097152/w=0/d=0, short=r=0/w=0/d=0, drop=r=0/w=0/d=0
READ: io=16384MB, aggrb=638864KB/s, minb=638864KB/s, maxb=638864KB/s, mint=26261msec, maxt=26261msec
dm-103: ios=2096456/28, merge=0/0, ticks=289497/82, in_queue=292714, util=99.93%, aggrios=2097152/30, aggrmerge=0/0, aggrticks=283241/82, aggrin_queue=286773, aggrutil=99.98%
dm-10: ios=2097152/30, merge=0/0, ticks=283241/82, in_queue=286773, util=99.98%, aggrios=0/0, aggrmerge=0/0, aggrticks=0/0, aggrin_queue=0, aggrutil=0.00%
drbd2: ios=0/0, merge=0/0, ticks=0/0, in_queue=0, util=0.00%, aggrios=2097152/30, aggrmerge=0/0, aggrticks=0/0, aggrin_queue=0, aggrutil=0.00%
md2: ios=2097152/30, merge=0/0, ticks=0/0, in_queue=0, util=0.00%, aggrios=1048576/56, aggrmerge=0/12, aggrticks=139041/39, aggrin_queue=113978, aggrutil=99.38%
nvme0n1: ios=1083541/56, merge=0/12, ticks=144908/39, in_queue=119789, util=99.38%
nvme1n1: ios=1013611/56, merge=0/12, ticks=133174/40, in_queue=108168, util=98.89%
[/share/CACHEDEV2_DATA/SSDVirtualMachine] # fio --name=randwrite --rw=randwrite --direct=1 --ioengine=libaio --bs=64k --numjobs=8 --size=512m --runtime=600 --group_reporting
randwrite: (g=0): rw=randwrite, bs=64K-64K/64K-64K/64K-64K, ioengine=libaio, iodepth=1
fio-2.2.10
randwrite: Laying out IO file(s) (1 file(s) / 512MB)
Jobs: 8 (f=8): [w(8)] [100.0% done] [0KB/343.2MB/0KB /s] [0/5490/0 iops] [eta 00m:00s]
randwrite: (groupid=0, jobs=8): err= 0: pid=10505: Sun Jun 2 15:50:11 2019
write: io=4096.0MB, bw=351341KB/s, iops=5489, runt= 11938msec
slat (usec): min=34, max=17637, avg=76.29, stdev=185.23
clat (usec): min=214, max=14232, avg=1368.17, stdev=540.81
lat (usec): min=266, max=18840, avg=1445.31, stdev=567.93
| 1.00th=[ 414], 5.00th=[ 860], 10.00th=[ 1096], 20.00th=[ 1256],
| 30.00th=[ 1304], 40.00th=[ 1320], 50.00th=[ 1336], 60.00th=[ 1352],
| 70.00th=[ 1368], 80.00th=[ 1384], 90.00th=[ 1448], 95.00th=[ 1736],
| 99.00th=[ 4048], 99.50th=[ 4960], 99.90th=[ 7136], 99.95th=[ 8256],
| 99.99th=[12992]
bw (KB /s): min=37888, max=47648, per=12.51%, avg=43942.38, stdev=1555.00
lat (usec) : 250=0.19%, 500=1.42%, 750=1.81%, 1000=4.15%
lat (msec) : 2=88.88%, 4=2.52%, 10=1.01%, 20=0.02%
cpu : usr=2.30%, sys=4.53%, ctx=66597, majf=0, minf=237
issued : total=r=0/w=65536/d=0, short=r=0/w=0/d=0, drop=r=0/w=0/d=0
WRITE: io=4096.0MB, aggrb=351340KB/s, minb=351340KB/s, maxb=351340KB/s, mint=11938msec, maxt=11938msec
dm-103: ios=0/65044, merge=0/0, ticks=0/82803, in_queue=82985, util=98.64%, aggrios=0/65939, aggrmerge=0/0, aggrticks=0/83510, aggrin_queue=83660, aggrutil=98.45%
dm-10: ios=0/65939, merge=0/0, ticks=0/83510, in_queue=83660, util=98.45%, aggrios=0/0, aggrmerge=0/0, aggrticks=0/0, aggrin_queue=0, aggrutil=0.00%
drbd2: ios=0/0, merge=0/0, ticks=0/0, in_queue=0, util=0.00%, aggrios=0/65939, aggrmerge=0/0, aggrticks=0/0, aggrin_queue=0, aggrutil=0.00%
md2: ios=0/65939, merge=0/0, ticks=0/0, in_queue=0, util=0.00%, aggrios=0/65598, aggrmerge=0/378, aggrticks=0/77059, aggrin_queue=69833, aggrutil=96.94%
nvme0n1: ios=0/65598, merge=0/378, ticks=0/76721, in_queue=69475, util=96.94%
nvme1n1: ios=0/65598, merge=0/378, ticks=0/77397, in_queue=70192, util=96.88%
[/share/CACHEDEV2_DATA/SSDVirtualMachine] # fio --name=randrw --rw=randrw --direct=1 --ioengine=libaio --bs=16k --numjobs=8 --rwmixread=90 --size=1G --runtime=600 --group_reporting
randrw: (g=0): rw=randrw, bs=16K-16K/16K-16K/16K-16K, ioengine=libaio, iodepth=1
fio-2.2.10
randrw: Laying out IO file(s) (1 file(s) / 1024MB)
Jobs: 8 (f=8): [m(8)] [100.0% done] [485.8MB/55992KB/0KB /s] [31.9K/3499/0 iops] [eta 00m:00s]
randrw: (groupid=0, jobs=8): err= 0: pid=18253: Sun Jun 2 15:51:24 2019
read : io=7354.2MB, bw=482299KB/s, iops=30143, runt= 15614msec
slat (usec): min=13, max=14696, avg=22.81, stdev=58.21
clat (usec): min=1, max=14210, avg=218.38, stdev=275.95
lat (usec): min=101, max=15877, avg=241.94, stdev=282.57
| 1.00th=[ 119], 5.00th=[ 131], 10.00th=[ 137], 20.00th=[ 147],
| 30.00th=[ 155], 40.00th=[ 163], 50.00th=[ 171], 60.00th=[ 181],
| 70.00th=[ 193], 80.00th=[ 209], 90.00th=[ 243], 95.00th=[ 298],
| 99.00th=[ 1704], 99.50th=[ 1816], 99.90th=[ 2992], 99.95th=[ 3728],
| 99.99th=[ 9280]
bw (KB /s): min=53748, max=68288, per=12.57%, avg=60608.70, stdev=2522.67
write: io=857984KB, bw=54950KB/s, iops=3434, runt= 15614msec
slat (usec): min=18, max=9544, avg=37.58, stdev=107.93
clat (usec): min=1, max=8729, avg=113.82, stdev=106.53
lat (usec): min=86, max=9551, avg=152.19, stdev=152.31
| 1.00th=[ 67], 5.00th=[ 71], 10.00th=[ 74], 20.00th=[ 80],
| 30.00th=[ 86], 40.00th=[ 93], 50.00th=[ 101], 60.00th=[ 109],
| 70.00th=[ 119], 80.00th=[ 135], 90.00th=[ 157], 95.00th=[ 181],
| 99.00th=[ 278], 99.50th=[ 402], 99.90th=[ 1256], 99.95th=[ 2416],
| 99.99th=[ 4576]
bw (KB /s): min= 5760, max= 8032, per=12.60%, avg=6924.03, stdev=443.43
lat (usec) : 2=0.01%, 4=0.07%, 10=0.02%, 20=0.01%, 50=0.03%
lat (usec) : 100=5.01%, 250=86.92%, 500=4.88%, 750=0.36%, 1000=1.06%
lat (msec) : 2=1.45%, 4=0.17%, 10=0.03%, 20=0.01%
cpu : usr=3.52%, sys=12.03%, ctx=538021, majf=0, minf=234
issued : total=r=470664/w=53624/d=0, short=r=0/w=0/d=0, drop=r=0/w=0/d=0
READ: io=7354.2MB, aggrb=482299KB/s, minb=482299KB/s, maxb=482299KB/s, mint=15614msec, maxt=15614msec
WRITE: io=857984KB, aggrb=54949KB/s, minb=54949KB/s, maxb=54949KB/s, mint=15614msec, maxt=15614msec
dm-103: ios=468896/53500, merge=0/0, ticks=94542/5702, in_queue=100761, util=99.51%, aggrios=470664/53634, aggrmerge=0/0, aggrticks=93600/5570, aggrin_queue=99814, aggrutil=99.42%
dm-10: ios=470664/53634, merge=0/0, ticks=93600/5570, in_queue=99814, util=99.42%, aggrios=0/0, aggrmerge=0/0, aggrticks=0/0, aggrin_queue=0, aggrutil=0.00%
drbd2: ios=0/0, merge=0/0, ticks=0/0, in_queue=0, util=0.00%, aggrios=470664/53634, aggrmerge=0/0, aggrticks=0/0, aggrin_queue=0, aggrutil=0.00%
md2: ios=470664/53634, merge=0/0, ticks=0/0, in_queue=0, util=0.00%, aggrios=235332/53636, aggrmerge=0/0, aggrticks=46509/4532, aggrin_queue=37832, aggrutil=97.77%
nvme0n1: ios=247017/53636, merge=0/0, ticks=49246/4496, in_queue=40350, util=97.77%
nvme1n1: ios=223647/53636, merge=0/0, ticks=43772/4569, in_queue=35314, util=96.07%
And results after changing the two NVME cards to RAID0.
- 670.49MB/s sequential read (1M) raid
- 748.54MB/s sequential read (1M) filesystem
- 401.1MB/s sequential read (8k)
- 548.6MB/s sequential write (32k)
- 332.2MB/s random read (8k)
- 682.1MB/s random write (64k)
- 458.8MB/s random read/write (16k)
[~] # qcli_storage -T force=1
Start testing!
NAS_HOST 1 /dev/sdc 119.25 MB/s /dev/md1 RAID 6 64.81 MB/s 1
NAS_HOST 2 /dev/sdd 105.34 MB/s /dev/md1 RAID 6 64.81 MB/s 1
NAS_HOST 3 /dev/sda 122.55 MB/s /dev/md1 RAID 6 64.81 MB/s 1
NAS_HOST 4 /dev/sdb 105.50 MB/s /dev/md1 RAID 6 64.81 MB/s 1
NAS_HOST P1-1 /dev/nvme1n1 768.83 MB/s /dev/md2 RAID 0 670.49 MB/s 288
NAS_HOST P1-2 /dev/nvme0n1 768.85 MB/s /dev/md2 RAID 0 670.49 MB/s 288
[~] # qcli_storage -t force=1
Start testing!
1 DataVol1 1 /dev/mapper/cachedev1 30.51 MB/s /share/CACHEDEV1_DATA 77.53 MB/s
2 DataVol2 288 /dev/mapper/cachedev2 774.48 MB/s /share/CACHEDEV2_DATA 748.54 MB/s
[/share/CACHEDEV2_DATA] # fio --name=seqread --rw=read --direct=1 --ioengine=libaio --bs=8k --numjobs=8 --size=1G --runtime=600 --group_reporting
fio-2.2.10
seqread: Laying out IO file(s) (1 file(s) / 1024MB)
Jobs: 8 (f=8): [R(8)] [100.0% done] [401.1MB/0KB/0KB /s] [51.5K/0/0 iops] [eta 00m:00s]
seqread: (groupid=0, jobs=8): err= 0: pid=10496: Sun Jun 2 23:12:00 2019
read : io=8192.0MB, bw=430141KB/s, iops=53767, runt= 19502msec
slat (usec): min=10, max=22046, avg=18.29, stdev=86.38
clat (usec): min=1, max=23132, avg=124.58, stdev=206.15
lat (usec): min=41, max=23144, avg=143.68, stdev=225.72
| 1.00th=[ 54], 5.00th=[ 58], 10.00th=[ 62], 20.00th=[ 70],
| 30.00th=[ 84], 40.00th=[ 99], 50.00th=[ 107], 60.00th=[ 115],
| 70.00th=[ 123], 80.00th=[ 137], 90.00th=[ 167], 95.00th=[ 209],
| 99.00th=[ 474], 99.50th=[ 828], 99.90th=[ 2960], 99.95th=[ 4128],
| 99.99th=[ 8512]
bw (KB /s): min=39328, max=62832, per=12.67%, avg=54500.98, stdev=4439.23
lat (usec) : 2=0.04%, 4=0.31%, 10=0.04%, 20=0.02%, 50=0.28%
lat (usec) : 100=40.42%, 250=55.76%, 500=2.21%, 750=0.37%, 1000=0.15%
lat (msec) : 2=0.22%, 4=0.13%, 10=0.05%, 20=0.01%, 50=0.01%
cpu : usr=3.95%, sys=12.98%, ctx=1099193, majf=0, minf=232
READ: io=8192.0MB, aggrb=430140KB/s, minb=430140KB/s, maxb=430140KB/s, mint=19502msec, maxt=19502msec
dm-96: ios=1044715/4, merge=0/0, ticks=97990/0, in_queue=98593, util=98.73%, aggrios=1048576/4, aggrmerge=0/0, aggrticks=95937/0, aggrin_queue=96630, aggrutil=98.26%
dm-95: ios=1048576/4, merge=0/0, ticks=95937/0, in_queue=96630, util=98.26%, aggrios=0/0, aggrmerge=0/0, aggrticks=0/0, aggrin_queue=0, aggrutil=0.00%
drbd2: ios=0/0, merge=0/0, ticks=0/0, in_queue=0, util=0.00%, aggrios=1048576/4, aggrmerge=0/0, aggrticks=0/0, aggrin_queue=0, aggrutil=0.00%
md2: ios=1048576/4, merge=0/0, ticks=0/0, in_queue=0, util=0.00%, aggrios=524288/8, aggrmerge=0/3, aggrticks=47452/7, aggrin_queue=32405, aggrutil=77.83%
nvme0n1: ios=524288/7, merge=0/2, ticks=48097/8, in_queue=33008, util=77.83%
nvme1n1: ios=524288/9, merge=0/4, ticks=46807/7, in_queue=31803, util=76.66%
[/share/CACHEDEV2_DATA] # fio --name=seqwrite --rw=write --direct=1 --ioengine=libaio --bs=32k --numjobs=4 --size=2G --runtime=600 --group_reporting
fio-2.2.10
seqwrite: Laying out IO file(s) (1 file(s) / 2048MB)
Jobs: 4 (f=4): [W(4)] [100.0% done] [0KB/548.6MB/0KB /s] [0/17.6K/0 iops] [eta 00m:00s]
seqwrite: (groupid=0, jobs=4): err= 0: pid=20382: Sun Jun 2 23:16:05 2019
write: io=8192.0MB, bw=582340KB/s, iops=18198, runt= 14405msec
slat (usec): min=19, max=16814, avg=46.25, stdev=131.23
clat (usec): min=1, max=25216, avg=166.66, stdev=289.13
lat (usec): min=94, max=25264, avg=213.96, stdev=320.21
| 1.00th=[ 3], 5.00th=[ 79], 10.00th=[ 86], 20.00th=[ 102],
| 30.00th=[ 114], 40.00th=[ 129], 50.00th=[ 141], 60.00th=[ 149],
| 70.00th=[ 157], 80.00th=[ 177], 90.00th=[ 219], 95.00th=[ 274],
| 99.00th=[ 740], 99.50th=[ 1320], 99.90th=[ 4192], 99.95th=[ 5792],
| 99.99th=[10176]
bw (KB /s): min=101248, max=171264, per=25.16%, avg=146508.38, stdev=13615.36
lat (usec) : 2=0.05%, 4=1.09%, 10=0.11%, 20=0.03%, 50=0.50%
lat (usec) : 100=16.41%, 250=75.38%, 500=4.70%, 750=0.77%, 1000=0.31%
lat (msec) : 2=0.36%, 4=0.19%, 10=0.10%, 20=0.01%, 50=0.01%
cpu : usr=6.37%, sys=13.15%, ctx=318518, majf=0, minf=104
WRITE: io=8192.0MB, aggrb=582340KB/s, minb=582340KB/s, maxb=582340KB/s, mint=14405msec, maxt=14405msec
dm-96: ios=0/261408, merge=0/0, ticks=0/33051, in_queue=33220, util=93.85%, aggrios=0/262308, aggrmerge=0/0, aggrticks=0/32202, aggrin_queue=32358, aggrutil=92.82%
dm-95: ios=0/262308, merge=0/0, ticks=0/32202, in_queue=32358, util=92.82%, aggrios=0/0, aggrmerge=0/0, aggrticks=0/0, aggrin_queue=0, aggrutil=0.00%
drbd2: ios=0/0, merge=0/0, ticks=0/0, in_queue=0, util=0.00%, aggrios=0/262308, aggrmerge=0/0, aggrticks=0/0, aggrin_queue=0, aggrutil=0.00%
md2: ios=0/262308, merge=0/0, ticks=0/0, in_queue=0, util=0.00%, aggrios=0/131082, aggrmerge=0/72, aggrticks=0/15699, aggrin_queue=7571, aggrutil=41.28%
nvme0n1: ios=0/131074, merge=0/0, ticks=0/15908, in_queue=7688, util=41.28%
nvme1n1: ios=0/131091, merge=0/145, ticks=0/15491, in_queue=7454, util=40.44%
[/share/CACHEDEV2_DATA] # fio --name=randread --rw=randread --direct=1 --ioengine=libaio --bs=8k --numjobs=16 --size=1G --runtime=600 --group_reporting
fio-2.2.10
Jobs: 6 (f=6): [_(3),r(1),_(2),r(1),_(2),r(1),_(1),r(2),_(2),r(1)] [100.0% done] [332.2MB/0KB/0KB /s] [42.6K/0/0 iops] [eta 00m:00s]
randread: (groupid=0, jobs=16): err= 0: pid=27236: Sun Jun 2 23:20:04 2019
read : io=16384MB, bw=560755KB/s, iops=70094, runt= 29919msec
slat (usec): min=10, max=34227, avg=20.51, stdev=85.64
clat (usec): min=1, max=43204, avg=192.48, stdev=254.52
lat (usec): min=43, max=43217, avg=213.89, stdev=270.04
| 1.00th=[ 91], 5.00th=[ 104], 10.00th=[ 111], 20.00th=[ 121],
| 30.00th=[ 131], 40.00th=[ 139], 50.00th=[ 151], 60.00th=[ 167],
| 70.00th=[ 189], 80.00th=[ 223], 90.00th=[ 278], 95.00th=[ 346],
| 99.00th=[ 716], 99.50th=[ 1288], 99.90th=[ 3504], 99.95th=[ 4640],
| 99.99th=[ 8640]
bw (KB /s): min=20496, max=52224, per=6.53%, avg=36594.84, stdev=5997.35
lat (usec) : 2=0.03%, 4=0.41%, 10=0.03%, 20=0.02%, 50=0.04%
lat (usec) : 100=2.38%, 250=82.84%, 500=12.37%, 750=0.94%, 1000=0.28%
lat (msec) : 2=0.35%, 4=0.24%, 10=0.06%, 20=0.01%, 50=0.01%
cpu : usr=3.32%, sys=9.10%, ctx=2180044, majf=0, minf=520
READ: io=16384MB, aggrb=560754KB/s, minb=560754KB/s, maxb=560754KB/s, mint=29919msec, maxt=29919msec
dm-96: ios=2096095/19, merge=0/0, ticks=270611/0, in_queue=273411, util=99.58%, aggrios=2097152/19, aggrmerge=0/0, aggrticks=265253/0, aggrin_queue=268605, aggrutil=99.30%
dm-95: ios=2097152/19, merge=0/0, ticks=265253/0, in_queue=268605, util=99.30%, aggrios=0/0, aggrmerge=0/0, aggrticks=0/0, aggrin_queue=0, aggrutil=0.00%
drbd2: ios=0/0, merge=0/0, ticks=0/0, in_queue=0, util=0.00%, aggrios=2097152/19, aggrmerge=0/0, aggrticks=0/0, aggrin_queue=0, aggrutil=0.00%
md2: ios=2097152/19, merge=0/0, ticks=0/0, in_queue=0, util=0.00%, aggrios=1048576/7, aggrmerge=0/2, aggrticks=131210/0, aggrin_queue=105271, aggrutil=93.75%
nvme0n1: ios=1048576/0, merge=0/0, ticks=131512/0, in_queue=105378, util=93.75%
nvme1n1: ios=1048576/14, merge=0/5, ticks=130909/0, in_queue=105165, util=93.39%
[/share/CACHEDEV2_DATA] # fio --name=randwrite --rw=randwrite --direct=1 --ioengine=libaio --bs=64k --numjobs=8 --size=512m --runtime=600 --group_reporting
fio-2.2.10
Jobs: 8 (f=7): [w(8)] [100.0% done] [0KB/682.1MB/0KB /s] [0/10.1K/0 iops] [eta 00m:00s]
randwrite: (groupid=0, jobs=8): err= 0: pid=5497: Sun Jun 2 23:22:44 2019
write: io=4096.0MB, bw=699750KB/s, iops=10933, runt= 5994msec
slat (usec): min=26, max=15193, avg=58.45, stdev=97.37
clat (usec): min=3, max=17323, avg=654.88, stdev=515.79
lat (usec): min=162, max=17462, avg=714.05, stdev=524.75
| 1.00th=[ 147], 5.00th=[ 247], 10.00th=[ 278], 20.00th=[ 358],
| 30.00th=[ 446], 40.00th=[ 524], 50.00th=[ 612], 60.00th=[ 676],
| 70.00th=[ 748], 80.00th=[ 836], 90.00th=[ 940], 95.00th=[ 1064],
| 99.00th=[ 2800], 99.50th=[ 3888], 99.90th=[ 6752], 99.95th=[ 7456],
| 99.99th=[12992]
bw (KB /s): min=77056, max=100736, per=12.58%, avg=88001.40, stdev=4983.58
lat (usec) : 4=0.01%, 10=0.01%, 20=0.01%, 100=0.01%, 250=5.39%
lat (usec) : 500=32.13%, 750=32.20%, 1000=23.34%
lat (msec) : 2=5.31%, 4=1.14%, 10=0.45%, 20=0.01%
cpu : usr=3.98%, sys=6.21%, ctx=67422, majf=0, minf=239
WRITE: io=4096.0MB, aggrb=699750KB/s, minb=699750KB/s, maxb=699750KB/s, mint=5994msec, maxt=5994msec
dm-96: ios=0/63345, merge=0/0, ticks=0/34440, in_queue=34597, util=97.57%, aggrios=0/65752, aggrmerge=0/0, aggrticks=0/35084, aggrin_queue=35202, aggrutil=96.97%
dm-95: ios=0/65752, merge=0/0, ticks=0/35084, in_queue=35202, util=96.97%, aggrios=0/0, aggrmerge=0/0, aggrticks=0/0, aggrin_queue=0, aggrutil=0.00%
drbd2: ios=0/0, merge=0/0, ticks=0/0, in_queue=0, util=0.00%, aggrios=0/65752, aggrmerge=0/0, aggrticks=0/0, aggrin_queue=0, aggrutil=0.00%
md2: ios=0/65752, merge=0/0, ticks=0/0, in_queue=0, util=0.00%, aggrios=0/32773, aggrmerge=0/103, aggrticks=0/17418, aggrin_queue=13642, aggrutil=80.26%
nvme0n1: ios=0/32773, merge=0/83, ticks=0/17588, in_queue=13808, util=80.26%
nvme1n1: ios=0/32773, merge=0/124, ticks=0/17249, in_queue=13476, util=79.69%
fio-2.2.10
Jobs: 8 (f=8): [m(8)] [100.0% done] [458.8MB/51059KB/0KB /s] [29.4K/3191/0 iops] [eta 00m:00s]
randrw: (groupid=0, jobs=8): err= 0: pid=16898: Sun Jun 2 23:28:34 2019
read : io=7354.2MB, bw=480423KB/s, iops=30026, runt= 15675msec
slat (usec): min=11, max=14991, avg=18.97, stdev=56.80
clat (usec): min=1, max=16844, avg=224.90, stdev=318.29
lat (usec): min=73, max=16864, avg=244.54, stdev=323.73
| 1.00th=[ 117], 5.00th=[ 129], 10.00th=[ 135], 20.00th=[ 145],
| 30.00th=[ 151], 40.00th=[ 159], 50.00th=[ 167], 60.00th=[ 177],
| 70.00th=[ 191], 80.00th=[ 211], 90.00th=[ 258], 95.00th=[ 370],
| 99.00th=[ 1704], 99.50th=[ 1928], 99.90th=[ 3792], 99.95th=[ 4960],
| 99.99th=[10176]
bw (KB /s): min=48512, max=70144, per=12.64%, avg=60713.13, stdev=4570.29
write: io=857984KB, bw=54736KB/s, iops=3420, runt= 15675msec
slat (usec): min=14, max=5240, avg=27.06, stdev=46.93
clat (usec): min=1, max=10871, avg=101.16, stdev=185.35
lat (usec): min=59, max=10913, avg=128.91, stdev=192.29
| 1.00th=[ 45], 5.00th=[ 48], 10.00th=[ 50], 20.00th=[ 54],
| 30.00th=[ 59], 40.00th=[ 64], 50.00th=[ 71], 60.00th=[ 81],
| 70.00th=[ 94], 80.00th=[ 116], 90.00th=[ 155], 95.00th=[ 203],
| 99.00th=[ 446], 99.50th=[ 772], 99.90th=[ 2832], 99.95th=[ 3440],
| 99.99th=[ 7072]
bw (KB /s): min= 5280, max= 8352, per=12.67%, avg=6935.60, stdev=626.39
lat (usec) : 2=0.01%, 4=0.09%, 10=0.01%, 20=0.01%, 50=0.96%
lat (usec) : 100=6.56%, 250=82.12%, 500=6.68%, 750=0.76%, 1000=0.84%
lat (msec) : 2=1.53%, 4=0.35%, 10=0.07%, 20=0.01%
cpu : usr=3.30%, sys=9.40%, ctx=538043, majf=0, minf=240
READ: io=7354.2MB, aggrb=480422KB/s, minb=480422KB/s, maxb=480422KB/s, mint=15675msec, maxt=15675msec
WRITE: io=857984KB, aggrb=54735KB/s, minb=54735KB/s, maxb=54735KB/s, mint=15675msec, maxt=15675msec
dm-96: ios=470587/53623, merge=0/0, ticks=87749/3343, in_queue=91518, util=98.62%, aggrios=470664/53633, aggrmerge=0/0, aggrticks=86736/3210, aggrin_queue=90421, aggrutil=98.38%
dm-95: ios=470664/53633, merge=0/0, ticks=86736/3210, in_queue=90421, util=98.38%, aggrios=0/0, aggrmerge=0/0, aggrticks=0/0, aggrin_queue=0, aggrutil=0.00%
drbd2: ios=0/0, merge=0/0, ticks=0/0, in_queue=0, util=0.00%, aggrios=470664/53633, aggrmerge=0/0, aggrticks=0/0, aggrin_queue=0, aggrutil=0.00%
md2: ios=470664/53633, merge=0/0, ticks=0/0, in_queue=0, util=0.00%, aggrios=235332/26817, aggrmerge=0/0, aggrticks=43304/1595, aggrin_queue=34579, aggrutil=76.16%
nvme0n1: ios=235529/26622, merge=0/1, ticks=43562/1514, in_queue=34518, util=76.16%
nvme1n1: ios=235135/27013, merge=0/0, ticks=43046/1676, in_queue=34641, util=71.92%
