Lately, I started to play around with Virtualization Station again and did setup a VM. It is running Debian 9.
After the NAS was asleep, the network is gone. (NAS is scheduled to sleep each night). To get the network connection back, I need to suspend/resume the VM.
Using VNC, I can do 'ip a' which prints a valid configuration for the network adapter. But I can't ping anything, neither local network nor public internet.
I got a TS-251 running 4.3.5.0722. Virtualization Station is 3.1.729 (2018-09-10). I have one physical port connected to the network (fixed IP), hooked up to a Virtual Switch. The VM is also hooked up to the same Virtual Switch.
How could I solve that problem?
VM no network after NAS sleep
Re: VM no network after NAS sleep
hello
same issue on the same qnap device model. If anyone found the solution please share with us.
Support informed they reproduced this issue in lab and they are working to fix it. we have to wait for new firmware update
How did you manage to suspend your VM on sleep automatically? My VM shutdowns everytime my NAS goes to sleep and it's stopped when I check after Wake-On-LAN.
- OneCD
