cannot select folder remote NAS
Hairy65
First post
Post by Hairy65 »
Hi
I'm using Virtualization station on my TS-473.
I want to make VM backups to my old TS-219. When I make a backup job I can select the TS-219. When I test the connection it is succesfull.
But I cannot select a folder in the location selectbox.
I see the NAS, but no folders as you can see in the picture.
Who knows th solution?
Martin
peripc
Re: cannot select folder remote NAS
Post by peripc »
i have exactly the same issue :(
With Virtualization Station on TS-473 and trying to backup at a TS-230
Return to “Virtualization Station”
