Could anyone help me resolve it ?
I first created the disk image
# /QVS/usr/bin/qemu-img create -f qcow2 ./debian8.qcow2 8G
Formatting './debian8.qcow2', fmt=qcow2 size=8589934592 cluster_size=65536 lazy_refcounts=off refcount_bits=16
and then I run the virt-install command...
# /QVS/usr/bin/virt-install \
> --name debian8 \
> --ram 1024 \
> --disk path=./debian8.qcow2,size=8 \
> --vcpus 1 \
> --os-type linux \
> --os-variant debianwheezy \
> --network bridge=virbr0 \
> --graphics none \
> --console pty,target_type=serial \
> --location 'http://ftp.nl.debian.org/debian/dists/jessie/main/installer-amd64/' \
> --extra-args 'console=ttyS0,115200n8 serial
Which results in the following..
Starting install...
Retrieving file MANIFEST...
| 3.3 kB 00:00:00 !!! Retrieving file linux...
| 6.0 MB 00:00:01 !!! Retrieving file initrd.gz...
| 29 MB 00:00:04 !!! ERROR Could not start storage pool: cannot open directory '/var/lib/libvirt/boot': No such file or directory
The closest I seem to have to that location is as follows, but looking inside, it looks empty ?
/QVS/var/lib/libvirt/boot
