Virtualization Station - German Keyboard not working since last update
cc13com
Post by cc13com »
since the last upate to VS version 3.5.56 my Linux VM with the German keyboard isn't working anymore.
To double check I created a new VM, set the German keyboard in the Virtualization Station settings and load a Linux ISO but the keyboard isn't working. If I change the keyboard setting in the VM to English the keyboard in the VM is working fine.
Any idea?
Thanks,
cc13
xpeperx
Re: Virtualization Station - German Keyboard not working since last update
Post by xpeperx »
hi,
i have the same issue since some weeks, german keyboard isn't working
Hardware: TS 653D
Firmware: 4.5.3.1670
Virtualization Station: V3.5.57 (2021/05/19)
any idea?
pepe74
First post
Post by pepe74 »
hi,
same here and my temporary solution is to use GERMAN(CH) Keyboard setting.
tusi79
Post by tusi79 »
Same issue here with Slovenian keyboard.
Virtualization Station: V3.5.68 (2021/11/09)
TS-453D
FW: 5.0.0.1870
Luckily it works over the ssh.
AntonioManuel
Getting the hang of things
Post by AntonioManuel »
Same problem with Portuguese keyboard.
I install a Linux Mint VM with English as Language and Interface and for the Region I use Portuguese along with for Time Format.
In VM it doesn't recognize the correct Keyboard, missing some characters, but if I use the SPICE client (virt-viewer) everything is ok.
Virtualization Station Versão3.6.13 (2022-01-20)
Thanks.
TVS-672XT
QTS 5.0.1.2145
Return to “Virtualization Station”
