Virtualization station supported models
koos147
Post by koos147 »
Good day,
when i search for the supported models, there is only a list with outdated models.
so i assume that all modern models support virtualization station.
Can someone confirm that? or otherwise point to the list of currently supported models.
i want a small windows server 2019 installation.
the size of the nas should be ~the same as a ts-219.
Kind regards
Mark
dolbyman
Re: Virtualization station supported models
Post by dolbyman »
Any current x86_x64 model supports virtualization.
If you want to run a windows server (GUi) on it..look higher up than a celeron model (ryzen or core il)
Return to “Virtualization Station”
