More than one virtual switch for VStation needed?
Blinky
Post by Blinky »
Hi everybody,
I have the Virtualization Station running on a TVS-671 updated to QTS 4.5.4 some days ago.
There are currently three VMs installed, all of which are connected to a virtual switch.
Now I wanted to import another VM, but I always get the message that I should create a virtual switch first?!?
Is there a maximum number of VMs per VirtSwitch? I sure I remember that I had more VMs without problems some time ago.
Thanks in advance...
QNAP TVS-671 i7-4770T 16GB
Blinky
Re: More than one virtual switch for VStation needed?
Post by Blinky »
Ok, I received an answer from the QNAP support and guess what – it was my fault:
The Virtualization Station does not support virtual switches with NAT/DHCP function.
I think I enabled NAT on the vSwitch for testing and didn't remember that. And existing VMs seems to run without problems but you can't create or import new ones...
Return to “Virtualization Station”
