Import to V.S. ... tests
Re: Import to V.S. ... tests
What do you like more? VS or Virtual Box at this point?
Well thanks for the information, I am having trouble with both VS and VB with regards to importing VM's from VMware.
I had a few VM's (Windows 2008 R2) that I want to use. Originally on ESXi 5.1, imported into VMware Workstation 10 then converted to OVF.
When I import the VM I got an error
Thoughts?
At this point for me I like VB over VS. I would like to see things from both but that's because I live and breath ESXi at work...and these wishes are for the dork at home
Thoughts?
First thank you Philippe!
Importing a VM from VMware that you need to do the following to be able to import the VM without a BSOD.
I exported the VM from ESXi into VMworstation 10.
Powered up and removed VMtools and unnecessary hardware. Serial/Floppy.
Changed the controller from SCSI to IDE
Restarted VM
Did export from VMWorkstation to OVF
Import into VT
Install VM Driver
Success!
Restarted VM
Import into VT
Install VM Driver
Success!
Restarted VM
Import into VT
Install VM Driver
Success!
Restarted VM
Import into VT
Install VM Driver
Success!
