Failed to delete note
csawjer
Post by csawjer »
Current Version of notes: 2.1.11
I have a section that I cannot delete. System tells me: failed to delete note.
Neither can I delete any note in this section. The only indication that something is amiss is the yellow star on the respective section in the section list.
Where can I find further explanations or a solution to the problem?
Thanks for any help
crambie
Re: Failed to delete note
Post by crambie »
I noticed that. It looks like those yellow starred ones are reserved, permanent ones that you can't remove. At least I couldn't find a way.
Ruud Westerhout
Getting the hang of things
Post by Ruud Westerhout »
Wow, so this is like '1,5 years old' and no solution?
I just started to use Notes Station.
Starting with a fresh clean slate would be nice. I received a few 'admin notes' which came with the default installation and I seem unable to delete it.
Looks like an authorization topic to me, is there no solution to this problem here?
Regards,
Ruud
TVS-873 (8GB) with 6x Seagate IronWolf 10TB in Raid6 FW 4.3.6.0923 Build 20190425
TS-419P with 4x Hitachi 4TB in Raid5 FW 4.3.3.0789 Build 20190102
CyberTears1994
Post by CyberTears1994 »
Ruud Westerhout wrote:Wow, so this is like '1,5 years old' and no solution?
Regards,
Ruud
Well, no. you need to submit a ticket to Qnap support if you need help.
Ruud Westerhout
Hello CyberTears1994,
The topic is not important enough (for me) to open a ticket.
After playing around with the tool it looks to me that the admin 's Notebook, especially its section My Notes is just a storage place for tasks and events (calendar items).
It feels a little strange, could have been solved better IMHO, but at it seems the only thing I cannot delete, I can live with that.
It might also be a topic solved in the later Notes Station 3. I am currently playing with 2.1, as I understood that version 3 might not work for me (I do not recall the reason).
But of course thanks for your quick reaction !
with best regards,
Ruud
Return to “Notes Station”
