eg, search for folder "NotesStation3", I received the results:
[/share/CACHEDEV1_DATA/.qpkg] # find ./ -name "NotesStation3"
./container-station/system-docker/overlay/82...cc/root/var/www/NotesStation3
./container-station/system-docker/overlay/44...50/root/var/www/NotesStation3
./container-station/system-docker/overlay/ad...89/root/var/www/NotesStation3
./container-station/system-docker/overlay/32...34/root/var/www/NotesStation3
./container-station/system-docker/overlay/14...da/root/var/www/NotesStation3
./container-station/system-docker/overlay/b2...90/upper/var/www/NotesStation3
./container-station/system-docker/overlay/b2...90/merged/var/www/NotesStation3
./NotesStation3
./NotesStation3/db/mysql/NotesStation3
Questions that i have:
- Why are there so many copies/folders of the same app?
- How do i check which folder is actual in use? (Through trial and error I found out that the ".../merged/..." folder is the active one)
- What is the difference between "root", "upper" and "merged" folders
