Notesstation 3.7.2 Update fails
compoman
First post
Post by compoman »
just tried to update to 3.7.2 - update failed, even a uninstall / reinstall fails. anyone else having problems?
System: TS-877
OS: 4.5.2.1630
Ingo
dolbyman
Re: Notesstation 3.7.2 Update fails
Post by dolbyman »
looks like the signature does not fit...either redownload the file again..or notify qnap support..maybe the signature needs a fix
Return to “Notes Station”
