i just noticed that my android qnotes2 was not working and while checking about it saw that it was removed from google play.
So i installed qnotes3 and uninstalled notes station 2 from my ts-228.
Now i try to find notes station 3 but no such luck.
Saw somewhere that it needs higher than my qts 4.3.6.1663 so am i out of luck?
It seems i can't go back to notes station 2 and can't go forward to station 3. Really?
Thank you.
notes station and ts-228
Re: notes station and ts-228
if the 228 is incompatible with the requirements (firmware version, container station) than you are stuck .. yes
nothing we can do here, you would need to complain to qnap via ticket
Understood, thanks for your reply.
