#2002 Cannot log in to the MySQL server
I have a TS-669L TurboNAS and recently update the firmware to 4.2.
Looks nice and all features are promising.
SQL Server Enabling: From Control Panel/SQL Server I enabled SQL Server (MariaDB 5.5.44) and TCP/IP networking on 3306 port.
phpMyAdmin: From Apps I installed phpMyAdmin on my NAS to access the db server.
Using the default user/password (root/admin) I cannot login into MySQL and end up with "#2002 Cannot log in to the MySQL server" error.
I tried to reset the db password: didn't work
I Disable/Enable MySQL server many times: didn't work
I clean all cookies and history from my browser: didn't work
I'm out of options here and I don't know what to do more to get access to MySQL db instance.
I need MySQL access as I cannot continue WordPress installation without db access credentials.
Is this a bug related to last firmware update 4.2 ?
Any ideeas what to do next are most welcomed as for now I'm stuck.
Many thanks.
Many thanks.
- Toxic17
Re: #2002 Cannot log in to the MySQL server
have a read of this thread in regards t your issue especially the comments from Patrick.
Also you may also want to clear you Web Browsers cache and Cookies.
Regards Simon
Qnap Downloads
MyQNap.Org Repository
Qnap Downloads
Thanks for your replay ... but I already did that and clean Web Browsers cache, cookies, history, browsing, form data, and more ... a complete clean up.Toxic17 wrote:have a read of this thread in regards t your issue especially the comments from Patrick.
Didn't help.
Where can I find Patrick's comments about similar issue?
Thank you,
O
- schumaku
Either change the PHPMyAdmin config to connect instead of 127.0.0.1 new to localhost ... or enable the TCP/IP connection feature in the NAS SQL Server control panel.
Using search before posting - #2002 ...
Thanks, but I already did thatschumaku wrote:Either change the PHPMyAdmin config to connect instead of 127.0.0.1 new to localhost ... or enable the TCP/IP connection feature in the NAS SQL Server control panel.
Still cannot connect to SQL using phpMyAdmin
Here is a piece of my common.inc.php file
* First server
$i++;
/* Authentication type */
$cfg['Servers'][$i]['auth_type'] = 'cookie';
/* Server parameters */
$cfg['Servers'][$i]['host'] = 'localhost';
$cfg['Servers'][$i]['connect_type'] = 'tcp';
$cfg['Servers'][$i]['compress'] = false;
/* Select mysql if your server does not have mysqli */
$cfg['Servers'][$i]['extension'] = 'mysqli';
$cfg['Servers'][$i]['AllowNoPassword'] = true;
This is a piece of my SQL settingsschumaku wrote:Either change the PHPMyAdmin config to connect instead of 127.0.0.1 new to localhost ... or enable the TCP/IP connection feature in the NAS SQL Server control panel.
- Toxic17
uninstall the phpmyadmin you have installed from app center.
then try this one.
http://qnap.community/viewtopic.php?f=42&t=12
you need to install GIT 2.1.0 first however.
http://forum.qnap.com/viewtopic.php?f=301&t=97220
then try this one.
Regards Simon
Qnap Downloads
Qnap Downloads
wow, thanks so much .... will try that asap and get back to you.Toxic17 wrote:uninstall the phpmyadmin you have installed from app center.
then try this one.
In case anyone else finds this topic, don't bother, the requested URL /viewtopic.php was not found on this server.Toxic17 wrote:uninstall the phpmyadmin you have installed from app center.
then try this one.
TS-453 Pro
Firmware 4.2.1
Firmware 4.2.1
I had the same problem managed to solved it.
I am running on a QNAP TS-220 running on firmware version 4.3.3.1677 Build 20210608
Fixed it out of trial and error. So I am no means an expert on the subject.
After creating the
Control Panel > Applications > SQL Server
Check Enable SQL Server (it was unchecked by default)
Click the Apply Button
After enabling SQL Server this solved my problem of login to phpMyAdmin with the username:root and the password: admin
After creating the
- OneCD
