I installed Nextcloud on a QNAP TS-251A and also installed a wildcard ssl.
It works fine so far, but at the backend there are serveral Security & setup warnings:
Could you please help me with the mentioned warnings?
- The "X-Frame-Options" HTTP header is not configured to equal to "SAMEORIGIN". This is a potential security or privacy risk and we recommend adjusting this setting.
No memory cache has been configured. To enhance your performance please configure a memcache if available. Further information can be found in our documentation.
Unfortunataly QNAP provides only php 5.6, to get rid of "memory cache warning" somehow i have to activate APCu on the QNAP.
Kind regards,
fps_user
