If I try to connect to ipnas/phpMyAdmis I got a blank page.
I have tried several times to reinstall phpMyAdmin, restart the NAS....none worked.
cannot login to phpMyAdmin
Re: cannot login to phpMyAdmin
phpmyadmin from a qpkg or directly from the original website?vidotto wrote:If I try to connect to ipnas/phpMyAdmis I got a blank page.
The webserver is enabled?
- schumaku
The Web server
- on http://[NAS_IP_address]:80/ is workable?
- http://[NAS_IP_address]:80/whatever.htm is serving a whatever.htm file for a test?
- http://[NAS_IP_address]:80/whatever.php (ie. a sample code of phpinfo) is run in php?
Can't connect to phpMyAdmin - getting "Error establishing a database connection." Obviously.
The last time this happened a month ago, a QNAP tech did a Putty session, but couldn't fix anything and suggested I downgrade. This helped as I was able to access my Websites. Yesterday I got an email from Pao Yang asking if I could again update to check if MySQL works. My guess was they made some changes.
This time tho downgrading only made the situation worse as almost every app is complaining it doesn't work with the older firmware. WOW.
Now I'm without access to the 20 Websites I have on this machine. Any suggestions?
TS-453 Pro
Firmware 4.2.1
Firmware 4.2.1
TS-453 Pro
Firmware 4.2.1
Firmware 4.2.1
NOT FIXED
Disregard my last - system restart this morning took care of what I got working yesterday. Back to a "#2002 - No such file or directory."
The system is just as busted and unreliable as on my TS509 from years ago, but at least we have a nicer UI to look at!
TS-453 Pro
Firmware 4.2.1
Firmware 4.2.1
