It seems like there is a DB app installed by default in 4.3.x which is modern (security patched) and I MAY switch to that if it continues to be patched OR if I have to due to the old DB app being broken.
Apps:
- NextCloud
- PHPMyAdmin
- I believe that I installed QMariaDB over 2 years ago to be able to work with OwnCloud (which I've since uninstalled but the db remains). I now use NextCloud.
I'm a bit confused if any of my NAS upgrades in the past 2 years have reintroduced/altered the database engine installed.
It appears that QMariaDB is used for all db's right now. Please help me confirm. - Once that is known, I will backup the databases (I have a script for that with QMariaDB that seems to work for 1 database at a time).
- Finally, I need to know what to do during an upgrade to 4.3.x. I will address the NextCloud config for repointing the DB as needed.
- Will QMariaDB still work?
- Do I need to remove it?
- Do I need to restore my database(s) into some new DB engine?
QNAP QTS Version 4.2.4
NAS: TS-651
- In the AppCenter, QMariaDB 5.5.44.002 appears
- In the SQL Server config it says QMariaDB 5.5.44.002 is used and is enabled on port 3306.
- In phpMyAdmin, there are databases for information_schema, mysql, nc, owncloud, performance_schema and test
(nc is for Nextcloud, I think test was me manually testing creating a db in phpmyadmin) - in the phpmyadmin User Accounts section, it shows user accoutns related to both owncloud and nextcloud, as well as root.
[/share/CACHEDEV1_DATA] # ls -a
./ .QKVM/ .php_session_sys/ .tmp/ Storage/
../ .antivirus/ .qbox_log_queue/ .torrent/ Web/
.@backup_config/ .appDB/ .qpkg/ .versioning/ aquota.user
.@backup_qbox/ .idmap/ .rnd Backups/ homes/
.@mysql/ .ldapdb/ .samba/ Download/ htdocs/
.@qmariadb/ .locks/ .spool/ Multimedia/ lost+found/
.@qsync/ .log/ .swap/ Public/
.@twonkymedia.db/ .php_session/ .system/ Recordings/
qMariaDB seems to be active and in use. (I have no clue though, so please help me)
[/share/CACHEDEV1_DATA] # ls -lta .@qmariadb/data
-rw-r----- 1 admin administ 5242880 Jul 15 13:23 ib_logfile0
-rw-rw---- 1 admin administ 139359198 Jul 15 13:23 mysql-bin.000048
-rw-r----- 1 admin administ 35651584 Jul 15 13:22 ibdata1
-rw-r----- 1 admin administ 5242880 Jul 15 08:58 ib_logfile1
drwxrwxrwx 7 admin administ 4096 May 27 12:20 ./
-rw-r----- 1 admin administ 134617 May 27 12:20 server.err
-rw-rw---- 1 admin administ 912 May 27 12:20 mysql-bin.index
-rw-rw---- 1 admin administ 16384 May 27 12:20 aria_log.00000001
-rw-rw---- 1 admin administ 52 May 27 12:20 aria_log_control
-rw-rw---- 1 admin administ 264 May 27 12:20 mysql-bin.000047
-rw-rw---- 1 admin administ 264 May 27 12:12 mysql-bin.000046
-rw-rw---- 1 admin administ 264 May 27 12:09 mysql-bin.000045
-rw-rw---- 1 admin administ 264 May 27 12:08 mysql-bin.000044
-rw-rw---- 1 admin administ 137290957 May 26 10:00 mysql-bin.000043
-rw-rw---- 1 admin administ 563 Apr 9 18:24 mysql-bin.000042
-rw-rw---- 1 admin administ 563 Apr 9 18:23 mysql-bin.000041
-rw-rw---- 1 admin administ 264 Apr 9 18:08 mysql-bin.000040
-rw-rw---- 1 admin administ 34517646 Apr 9 17:53 mysql-bin.000039
drwx------ 2 admin administ 4096 Dec 15 2016 nc/
-rw-rw---- 1 admin administ 862 Nov 19 2016 mysql-bin.000038
-rw-rw---- 1 admin administ 563 Nov 19 2016 mysql-bin.000037
-rw-rw---- 1 admin administ 264 Nov 19 2016 mysql-bin.000036
-rw-rw---- 1 admin administ 563 Nov 19 2016 mysql-bin.000035
-rw-rw---- 1 admin administ 2070793 Nov 18 2016 mysql-bin.000034
-rw-rw---- 1 admin administ 264 Nov 8 2016 mysql-bin.000033
-rw-rw---- 1 admin administ 563 Nov 8 2016 mysql-bin.000032
-rw-rw---- 1 admin administ 16438 Nov 8 2016 mysql-bin.000031
-rw-rw---- 1 admin administ 563 Nov 8 2016 mysql-bin.000030
-rw-rw---- 1 admin administ 264 Nov 8 2016 mysql-bin.000029
-rw-rw---- 1 admin administ 1795624 Nov 7 2016 mysql-bin.000028
drwx------ 2 admin administ 4096 Oct 29 2016 owncloud/
-rw-rw---- 1 admin administ 1345 Oct 27 2016 mysql-bin.000027
-rw-rw---- 1 admin administ 264 Oct 27 2016 mysql-bin.000026
-rw-rw---- 1 admin administ 264 Oct 27 2016 mysql-bin.000025
-rw-rw---- 1 admin administ 264 Oct 27 2016 mysql-bin.000024
-rw-rw---- 1 admin administ 7811158 Oct 27 2016 mysql-bin.000023
-rw-rw---- 1 admin administ 264 Aug 7 2016 mysql-bin.000022
-rw-rw---- 1 admin administ 563 Aug 7 2016 mysql-bin.000021
-rw-rw---- 1 admin administ 15061898 Aug 6 2016 mysql-bin.000020
-rw-rw---- 1 admin administ 264 Jul 18 2016 mysql-bin.000019
-rw-rw---- 1 admin administ 563 Jul 18 2016 mysql-bin.000018
-rw-rw---- 1 admin administ 10868 Jul 17 2016 mysql-bin.000017
-rw-rw---- 1 admin administ 264 Jul 17 2016 mysql-bin.000016
-rw-rw---- 1 admin administ 264 Jul 16 2016 mysql-bin.000015
-rw-rw---- 1 admin administ 7934876 Jul 12 2016 mysql-bin.000014
-rw-rw---- 1 admin administ 15685178 Apr 21 2016 mysql-bin.000013
-rw-rw---- 1 admin administ 264 Sep 27 2015 mysql-bin.000012
-rw-rw---- 1 admin administ 264 Sep 25 2015 mysql-bin.000011
-rw-rw---- 1 admin administ 1528435 Sep 25 2015 mysql-bin.000010
-rw-rw---- 1 admin administ 288 Sep 19 2015 mysql-bin.000009
-rw-rw---- 1 admin administ 1841606 Sep 19 2015 mysql-bin.000008
-rw-rw---- 1 admin administ 288 Sep 19 2015 mysql-bin.000007
-rw-rw---- 1 admin administ 264 Sep 19 2015 mysql-bin.000006
-rw-rw---- 1 admin administ 120863 Sep 19 2015 mysql-bin.000005
-rw-rw---- 1 admin administ 303700 Sep 12 2015 mysql-bin.000004
-rw-rw---- 1 admin administ 264 Sep 12 2015 mysql-bin.000003
-rw-rw---- 1 admin administ 33046 Aug 19 2015 mysql-bin.000002
-rw-rw---- 1 admin administ 264 Aug 19 2015 mysql-bin.000001
drwx------ 2 admin administ 4096 Aug 19 2015 mysql/
drwx------ 2 admin administ 4096 Aug 19 2015 performance_schema/
-rw-r--r-- 1 admin administ 3439 Aug 19 2015 upgrade.log
drwx------ 2 admin administ 4096 Aug 19 2015 test/
drwxr-xr-x 4 admin administ 4096 Aug 19 2015 ../
[/share/CACHEDEV1_DATA] # ls -alt .@mysql/
drwxrwxrwx 36 admin administ 4096 Jun 13 22:56 ../
-rw-rw---- 1 admin administ 52892 Aug 19 2015 server.err
-rw-rw---- 1 admin administ 5242880 Aug 19 2015 ib_logfile0
-rw-rw---- 1 admin administ 5242880 Aug 19 2015 ib_logfile1
-rw-rw---- 1 admin administ 18874368 Aug 19 2015 ibdata1
drwxrwxrwx 5 admin administ 4096 Aug 17 2015 ./
drwx------ 2 admin administ 4096 Apr 19 2015 owncloud/
drwx------ 2 admin administ 4096 Sep 4 2014 mysql/
drwx------ 2 admin administ 4096 Sep 4 2014 test/
