with last update i have this error when i try to open phpMyAdmin web page:
PHP 5.5.27
phpMyAdmin Q4.0.10.20
QNAP 4.3.3.0361 build 20171101
The mbstring extension is missing. Please check your PHP configuration.
i tryed to reinstall phpMyAdmin- without result.
The extension (mbstring.so) are present in these folders:
/mnt/ext/opt/apache/modules/
and
/share/HDA_DATA/.qpkg/PHP/modules
and it is present inside this file
/etc/config/php.d/ext.ini
someone can help me?
phpMyAdmin error - The mbstring extension is missing. Please check your PHP configuration.
Re: phpMyAdmin error - The mbstring extension is missing. Please check your PHP configuration.
i have checked if the module is loaded
[/] # php -m
[PHP Modules]
bcmath
bz2
calendar
ctype
date
dba
dom
exif
filter
ftp
hash
json
libxml
mbstring
openssl
pcre
posix
Reflection
session
shmop
SimpleXML
sockets
SPL
standard
sysvmsg
sysvsem
sysvshm
tokenizer
xml
xmlwriter
xsl
zlib
[Zend Modules]
[/] # php -m
[PHP Modules]
bcmath
bz2
calendar
ctype
date
dba
dom
exif
filter
ftp
hash
json
libxml
mbstring
openssl
pcre
posix
Reflection
session
shmop
SimpleXML
sockets
SPL
standard
sysvmsg
sysvsem
sysvshm
tokenizer
xml
xmlwriter
xsl
zlib
[Zend Modules]
- Toxic17
Try installing a newer phpmyadmin to your unknown NAS. 4.7.4 is the latest by QNAP.
https://www.qnap.com/en-uk/app_center/c ... 3.3&seq=92
or manually install it here:
https://files.phpmyadmin.net/phpMyAdmin ... guages.zip
uninstall phpmyadmin from app center. then extract zip file to the Web Folder. edit the config.user.inc.php to your requirements, and thats it. also use a .htaccess to block any external access from the net.
Regards Simon
Qnap Downloads
MyQNap.Org Repository
NAS: TS-673A QuTS hero h5.1.6.25734 • TS-121 4.3.3.2420 • APC Back-UPS ES 850G2
Network: VM Hub3: 500/50 • UniFi UDM Pro: 3.2.12 • UniFi Network Controller: 8.1.127
USW-Aggregation: 7.0.50 • US-16-150W: 7.0.50 • US-8-60W: 7.0.50 • 2x USW Mini Flex 2.0.0 • UniFi AC Pro 6.6.69 • UniFi U6-LR 6.6.69
UniFi Protect: 3.0.26/8TB Skyhawk AI • 3x G3 Instants: 4.70.39 • UniFi G3 Flex: 4.70.39 • UniFi G5 Flex: 4.70.39
Qnap Downloads
With new phpMyAdmin i have this error:Toxic17 wrote:Try installing a newer phpmyadmin to your unknown NAS. 4.7.4 is the latest by QNAP.
Fatal error: Call to undefined function Symfony\Polyfill\Mbstring\iconv_strpos() in /share/HDA_DATA/Web/phpMyAdmin2/vendor/symfony/polyfill-mbstring/Mbstring.php on line 363
- Toxic17
looks like something missing in the compilation of php...
I'm guessing you could try newer beta firmware.
https://www.qnap.com/en-uk/download?mod ... y=firmware QTS 4.3.4 Build 0374.
my build in php is version: 5.6.31.
If after that you still have issues, I would Submit a ticket with QNAP to either raise awareness the firmware for the TS-131P has an incomplete PHP installation or it needs updating to the same as other 4.3.4 QTS's
Regards Simon
Qnap Downloads
Qnap Downloads
I removed the PHP version listed in my app center, without any re-installation, maybe this is an old version i installed many time ago.
the release listed now is PHP: 5.6.31
Is the PHP a built-in feature on QNAP?
Now it works fine.
Now it works fine.
Exactly the same issue, and the same soution: Deleted php 5.5.27 app, and access was granted iin phpMyAdmin.
