QNAP WOL packet send GUI control
Hi, I have the QNAP TS-228 NAS and I would like to use it as an WOL magic packet sender. I found the QWOL app, but I need to start the wake function from the internet (not my LAN) and I do only have the NAS GUI port (443) openned (can't open any other ports because of my provider).
I can send the magic packet using sh script (viewtopic.php?t=76012), but I need to start it using an button in GUI, not the app's webserver.
I know that every qpkg has it's start/stop script. My question is: Can I modify this script to send the wake packet when starting an qpkg from the App center? Or is there any other way to start sh script from the GUI without openning any other ports?
Thanks for replies
Thanks for replies
- storageman
Re: QNAP WOL packet send GUI control
You know Qfinder has WOL option I presume.
I want the NAS to send WOL packet and wake a PC.storageman wrote:You know Qfinder has WOL option I presume.
- storageman
dId you see this?ondras wrote:I want the NAS to send WOL packet and wake a PC.storageman wrote:You know Qfinder has WOL option I presume.
viewtopic.php?t=64857
I don't have acces to my router from the internet. I need to solve this only with the NAS itself and only over the 443 port NAS GUI.storageman wrote:dId you see this?ondras wrote:I want the NAS to send WOL packet and wake a PC.storageman wrote:You know Qfinder has WOL option I presume.
- storageman
What about the wakelan stuff mentioned???
The command needs to be executed somehow. I do not have ssh port open, so I need to execute it from GUI. The only way to do this i found is modifying the start/stop script.storageman wrote:What about the wakelan stuff mentioned???
Yes, but it would be better for you to create your own QPKG with your own start/stop script rather than hacking another QPKG's script.ondras wrote:Can I modify this script to send the wake packet when starting an qpkg from the App center?
Yes, that's a better solution. I'll search the forum for information about creating QPKGs. Thanks for replies.Mousetick wrote:Yes, but it would be better for you to create your own QPKG with your own start/stop script rather than hacking another QPKG's script.ondras wrote:Can I modify this script to send the wake packet when starting an qpkg from the App center?
You may want to take a look at this: QNAP Development Kit.
You can install the QDK on the NAS itself from the App Center (https://www.qnap.com/en/app_center/?kw=qdk). But the link above is useful because of the documentation.
This allows you to create a skeleton QPKG. You edit the package configuration (qpkg.cfg) according to your needs. Then you add your start/stop script to the package. Then you "build" the QPKG. Finally you install it with App Center.
I have created the QPKG, installed it and it's not working. I used entware to install etherwake. When I run etherwake MAC from the ssh console, it wakes the pc correctly. But when I include it in the start script, it does not work. I haven't modified anything except this script. Where can I find a log from the script's execution? Why does it not work?
Thanks for anwsers.
Thanks for anwsers.
- OneCD
Can you post your init script?ondras wrote:When I run etherwake MAC from the ssh console, it wakes the pc correctly. But when I include it in the start script, it does not work. I haven't modified anything except this script. Where can I find a log from the script's execution? Why does it not work?
Yeah, show your script. You probably need to specify the full /path/to/etherwake command, because it's not in the $PATH of the QPKG's environment.
- Don
Why are you exposing the GUI interface to the internet. You are asking for trouble.
The only command I added to the start script is
etherwake my_comuter's_MAC
(Yes, I added it before the ;; line)
I also think I need the full path, but I couldn't find where is it located.
