Hi
I had websites running on my QNAP with virtual hosting. I was just starting and redid everything to have a clean start agian.
Now I have 2 virtual host defined, but get an error: server refused connection.
When I stop virtual hosting and upload wordpress under /web/ then I am redirected to the administration page of qnap.
I tried everything. Reset web service, reset PHP, delete web directory again, but nothing works.
Which analysis tools exist to find out what is wrong?
Thanks for your help,
Server refused connection for websites on virtual hosting
Re: Server refused connection for websites on virtual hosting
Wow I'm so glad I found your post.
I'm experiencing exactly the same thing here.
I got in touch with the french support, we're trying to find a solution, which we haven't yet.
Please keep in touch if you find a solution from your side, I will as well.
I started from scratch so here is what I did :
Set my server on DHCP constant IP both on my router and on the Qnap
Re-directed port 80 and port 8081 on my router
Enabled the SQL server
Installed phpmyadmin
Created a database on phpmyadmin
Enabled web server
Made sure that ports were set up to 80 and 8081 for secure connection
Installed WordPress
Linked WordPress to my database on phpMyadmin
on my domain provider, I redirected my domain to my IP address.
At this point, everything should actually be "brand new". What I actually got is a redirect to my admin qnap page when I'm searching for both http://mydomain.com and httpS://mydomain.com
When trying to delete index.php I get a forbidden error on httpS://... and the servers tries to redirect to the admin page on http:// but takes too much time to respond.
I've started from scratch at least 8 to 10 times, nothing is working and I can't figure out what I'm doing wrong.
Enabled web server
Installed WordPress
Dear all,
I found a solution.
There were two errors.
First step:
[~] # /etc/init.d/Qthttpd.sh stop
[~] # cp /etc/default_config/apache.conf /etc/config/apache/apache.conf
[~] # /etc/init.d/Qthttpd.sh start
This is from another thread.
Then I saw that the subdirectories are not copied to the /web/.../ directories
Now it is working.
Regards,
Arthur
I found a solution.
First step:
Now it is working.
Regards,
Arthur
Hello Arthur,
Could you please add some lines about this? I am afraid I don't understand the way to fix the error with what you wrote.
Where did you write this?
I don't understand the error therefore I don't understand your solution :/
Staf
Staf
I'm getting the same errors. Files are where they are supposed to be however, it seems that the contents of httpd-vhosts-user.conf are almost entirely ignored. I've checked to ensure that the file is included in the main httpd.conf files, and I've done some hand editing to test that different ports are listened to, etc, but for some reason, only the main host works, but none of the virtual ones.
Here are the contents of my config file; very simple:
NameVirtualHost *:80
<VirtualHost _default_:80>
DocumentRoot "/share/Web"
</VirtualHost>
<VirtualHost *:80>
<Directory "/share/Web">
Options FollowSymLinks MultiViews
AllowOverride All
Require all granted
</Directory>
ServerName www.xyz.dev
DocumentRoot "/share/Web/xyz"
</VirtualHost>
</VirtualHost>
<VirtualHost *:80>
AllowOverride All
Require all granted
</Directory>
</VirtualHost>
Stafylocok, use PuTTY to connect over SSH wit your station. You can read this file homenas mentioned "etc/default_config/apache.conf". The start and stop command is for the apache service.
Just copied the contents of each file here for everyone:
(My current) "/etc/config/apache/apache.conf"
There are differences between both fies, but I can't explain, how and why should this happen.
#ServerType standalone
ServerRoot "/usr/local/apache"
Mutex file:/var/lock/ default
PidFile /var/lock/apache.pid
#ScoreBoardFile /usr/local/apache/logs/apache.scoreboard
Timeout 300
KeepAlive On
MaxKeepAliveRequests 100
KeepAliveTimeout 15
ServerLimit 4
StartServers 2
MaxClients 256
MinSpareThreads 32
MaxSpareThreads 120
ThreadsPerChild 64
MaxRequestsPerChild 1000
Listen 80
User admin
Group administrators
ServerAdmin admin@NAS
#ServerName NAS
TraceEnable off
ServerTokens Prod
DocumentRoot "/share/Qweb"
<Directory />
AllowOverride None
Require all denied
</Directory>
<Directory "/share/Qweb">
AllowOverride All
Require all granted
</Directory>
Include /etc/config/apache/extra/apache-default-modules.conf
<IfModule headers_module>
Header always append X-Frame-Options SAMEORIGIN "env=!share-iframe"
Header always edit Set-Cookie ^(.*)$ $1;HttpOnly
</IfModule>
<IfModule dir_module>
DirectoryIndex index.html index.htm index.php
</IfModule>
AccessFileName .htaccess
<FilesMatch "^\.ht">
Require all denied
Satisfy All
</FilesMatch>
UseCanonicalName Off
HostnameLookups Off
<Directory "/usr/local/apache/cgi-bin">
AllowOverride None
Options None
Require all granted
</Directory>
ErrorLog logs/error_log
# LogLevel: Control the number of messages logged to the error_log.
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel crit
<IfModule log_config_module>
LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined
LogFormat "%h %l %u %t \"%r\" %>s %b" common
LogFormat "%{Referer}i -> %U" referer
LogFormat "%{User-agent}i" agent
<IfModule logio_module>
LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\" %I %O" combinedio
</IfModule>
#CustomLog logs/access_log common
# If you prefer a logfile with access, agent, and referer information
# (Combined Logfile Format) you can use the following directive.
#CustomLog logs/access_log combined
</IfModule>
# Aliases: Add here as many aliases as you need (with no limit). The format is
# Alias fakename realname
<IfModule alias_module>
Alias /v3_menu/ "/home/httpd/v3_menu/"
<Directory "/home/httpd/v3_menu">
AllowOverride None
Require all granted
</Directory>
</IfModule>
<IfModule autoindex_module>
AddIconByEncoding (CMP,/icons/compressed.gif) x-compress x-gzip
AddIconByType (TXT,/icons/text.gif) text/*
AddIconByType (IMG,/icons/image2.gif) image/*
AddIconByType (SND,/icons/sound2.gif) audio/*
AddIconByType (VID,/icons/movie.gif) video/*
AddIcon /icons/binary.gif .bin .exe
AddIcon /icons/binhex.gif .hqx
AddIcon /icons/tar.gif .tar
AddIcon /icons/world2.gif .wrl .wrl.gz .vrml .vrm .iv
AddIcon /icons/compressed.gif .Z .z .tgz .gz .zip
AddIcon /icons/a.gif .ps .ai .eps
AddIcon /icons/layout.gif .html .shtml .htm .pdf
AddIcon /icons/text.gif .txt
AddIcon /icons/c.gif .c
AddIcon /icons/p.gif .pl .py
AddIcon /icons/f.gif .for
AddIcon /icons/dvi.gif .dvi
AddIcon /icons/uuencoded.gif .uu
AddIcon /icons/script.gif .conf .sh .shar .csh .ksh .tcl
AddIcon /icons/tex.gif .tex
AddIcon /icons/bomb.gif core
AddIcon /icons/back.gif ..
AddIcon /icons/hand.right.gif README
AddIcon /icons/folder.gif ^^DIRECTORY^^
AddIcon /icons/blank.gif ^^BLANKICON^^
DefaultIcon /icons/unknown.gif
ReadmeName README.html
HeaderName HEADER.html
IndexIgnore .??* *~ *# HEADER* README* RCS CVS *,v *,t
</IfModule>
# Document types.
<IfModule mime_module>
TypesConfig /etc/config/apache/mime.types
AddLanguage da .dk
AddLanguage nl .nl
AddLanguage en .en
AddLanguage et .ee
AddLanguage fr .fr
AddLanguage de .de
AddLanguage el .el
AddLanguage he .he
AddCharset ISO-8859-8 .iso8859-8
AddLanguage it .it
AddLanguage ja .ja
AddCharset ISO-2022-JP .jis
AddLanguage kr .kr
AddCharset ISO-2022-KR .iso-kr
AddLanguage nn .nn
AddLanguage no .no
AddLanguage pl .po
AddCharset ISO-8859-2 .iso-pl
AddLanguage pt .pt
AddLanguage pt-br .pt-br
AddLanguage ltz .lu
AddLanguage ca .ca
AddLanguage es .es
AddLanguage sv .sv
AddLanguage cs .cz .cs
AddLanguage ru .ru
AddLanguage zh-TW .zh-tw
AddCharset Big5 .Big5 .big5
AddCharset WINDOWS-1251 .cp-1251
AddCharset CP866 .cp866
AddCharset ISO-8859-5 .iso-ru
AddCharset KOI8-R .koi8-r
AddCharset UCS-2 .ucs2
AddCharset UCS-4 .ucs4
AddCharset UTF-8 .utf8
<IfModule negotiation_module>
LanguagePriority en da nl et fr de el it ja kr no pl pt pt-br ru ltz ca es sv tw
</IfModule>
AddType application/x-tar .tgz
AddEncoding x-compress .Z
AddEncoding x-gzip .gz .tgz
AddType application/x-compress .Z
AddType application/x-gzip .gz .tgz
AddType application/x-httpd-php .php .php4 .php3 .phtml
AddType application/x-httpd-php-source .phps
AddHandler cgi-script .cgi
AddType text/html .shtml
AddHandler server-parsed .shtml
AddHandler send-as-is asis
AddHandler imap-file map
AddHandler type-map var
</IfModule>
<IfModule mime_magic_module>
MIMEMagicFile /etc/config/apache/magic
</IfModule>
<IfModule setenvif_module>
BrowserMatch "Mozilla/2" nokeepalive
BrowserMatch "MSIE 4\.0b2;" nokeepalive downgrade-1.0 force-response-1.0
BrowserMatch "RealPlayer 4\.0" force-response-1.0
BrowserMatch "Java/1\.0" force-response-1.0
BrowserMatch "JDK/1\.0" force-response-1.0
</IfModule>
<IfModule ssl_module>
SSLRandomSeed startup builtin
SSLRandomSeed connect builtin
</IfModule>
<IfModule reqtimeout_module>
RequestReadTimeout header=20-40,MinRate=500 body=20,MinRate=500
</IfModule>
Include /etc/config/apache/extra/apache-fastcgi.conf
Timeout 300
KeepAlive On
KeepAliveTimeout 15
ServerLimit 4
StartServers 3
MaxClients 256
MinSpareThreads 32
MaxSpareThreads 120
ThreadsPerChild 64
Listen 80
User httpdusr
#ServerName NAS
TraceEnable off
ServerTokens Prod
<Directory />
AllowOverride None
Require all denied
</Directory>
AllowOverride All
Require all granted
</Directory>
Header unset X-Frame-Options
</IfModule>
</IfModule>
Require all denied
Satisfy All
</FilesMatch>
HostnameLookups Off
AllowOverride None
Options None
Require all granted
</Directory>
ErrorLog /dev/null
# alert, emerg.
LogLevel crit
</IfModule>
</IfModule>
AllowOverride None
Require all granted
</Directory>
</IfModule>
</IfModule>
# Document types.
AddLanguage da .dk
AddLanguage nl .nl
AddLanguage en .en
AddLanguage et .ee
AddLanguage fr .fr
AddLanguage de .de
AddLanguage el .el
AddLanguage he .he
AddLanguage it .it
AddLanguage ja .ja
AddLanguage kr .kr
AddLanguage nn .nn
AddLanguage no .no
AddLanguage pl .po
AddLanguage pt .pt
AddLanguage ltz .lu
AddLanguage ca .ca
AddLanguage es .es
AddLanguage sv .sv
AddLanguage ru .ru
</IfModule>
</IfModule>
</IfModule>
</IfModule>
</IfModule>
</IfModule>
Include /etc/config/apache/extra/apache-force-ssl.conf
Include /etc/config/apache/extra/apache-ssl.conf
Include /etc/config/apache/extra/apache-video.conf
Include /etc/config/apache/extra/apache-http-compress.conf
Include /etc/config/apache/extra/apache-musicstation.conf
Include /etc/config/apache/extra/apache-photo.conf
I followed the first steps mentioned by homenas, but starting the internal Apache web server just broguht me the version of my apache.conf back, which differs to the one from "default_config" folder. So is this useless?
I'm not sure what homenas meant by fixing the second error, because he had seen that there are no subfolders copied. Not sure what does this mean.
- jaysona
- Been there, done that
I'm fairly certain that after 17 months, the OP has sorted out their issue - or does not really care anymore about the post that is nearly one and a half years old.......
RAID is not a Back-up!
H/W: TS-219 Pro / TS-509 Pro
jaysona, you could be right, but this issue is yet not closed and I' facing the same problem in 2020. There is no complete solution provided, questions open and those who will search and find this topic might struggle to understand what they're talking about. I brought light into this topic. My concern is not to warm up leftovers, rather help to find a solution.
