How do I install missing PHP modules (intl)?
Hello there,
I have much anticipated the recent update to PHP Version 7.3.7, but it's still giving me major headaches.
I want to run an owncloud 10.3 server on a TS-251A (QTS 4.4.1.1086), but it won't run because it is missing the PHP module intl, which is required for owncloud.
Hence my question: How do I install missing php modules on my QNAP NAS?
Re: How do I install missing PHP modules (intl)?
Same problem here, how to install intl, apcu,imagik... ?
Will be interested too, for the same reason...
TVS-863 owner
Hi
have you find a solution?
Tanks
Tanks
I'm running QTS 4.4.1 with PHP 7.3.7 and want to install/active the int module.
Anyone got a solution?
thanks
thanks
- Been there, done that
No success yet?
QTS 4.1.n/4.2.n/4.3.n/4.4.n MANUAL
Submit QNAP Support Ticket - QNAP Tutorials, Wiki - Product Support Status - Moogle's QNAP FAQ help V2 - QNAP Security Advisory
When you ask a question, please include the following:
Data md_checker nasreport (release 20180525)
Model: TVS-873e -- RAM: 20G -- FW: QTS 5.1.1.2491 build 20230815 (used as main storage + applications)
WD60EFRX-68L0BN1(x6) / WD80EFAX-68LHPN0(x1) Red HDDs -- RAID5: 8x6TB -- Cold spare: None
Model: TS-453B -- RAM: 8G -- FW: QTS 4.4.1.0978 build 20190626 -- BROKEN
Model: SS-839 -- SOLD after 12 years use! Never lost ANY data!
13 years of QNAP experience + Asustor and WD!
Hello
I'm looking for a solution to the same question. How do I activate php_intl
I run a 453B with QTS 4.4.2 and using PHP 7.3.7
thanks in advance
thanks in advance
i have the same problem. I need php_intl for a Nextcloud Installation on Qnap TS-253Be, QTS 4.4.2, PHP 7.3.7.
thx
thx
i have the same problem. I need php_intl too into my QTS 4.4.2.1310 and using PHP 7.3.7.
thx
thx
did anyone have luck so far?
No!
- jaysona
The module is available via entware.
[~] # opkg list
php7-mod-intl - 7.1.12-3 - Internationalization Functions shared module
RAID is not a Back-up!
H/W: TS-219 Pro / TS-509 Pro
Hi jaysona,
I just found Entware, installed the opkg package (opkg install php7-mod-intl) without any errors. But still can't install ownclound as the original poster.
I added in the php.ini the line "extension=intl". I also put a user.ini and or php.ini in the owncloud folder and restarted the qnap webserver (QThttpd.sh). still no luck. any thoughts?
opkg shows also "php7-mod-intl - 7.4.6-1" installed. is 7.4.6 the php version?? maybe that's the issue. Qnaps webserver runs on 7.3.7
- jaysona
Ummmm........I thought php modules extensions ended with a .so. The files installed would be listed as part of the opkg installation process, and there shoul dhave been at least one file ending in .so that was installed.blablub233 wrote: ↑Sun Jul 05, 2020 6:59 am Hi jaysona,
You would need to modify your php.ini file to include the new module extension, and also make sure the proper symlinks are in place.
i add successfully apcu and intl to my ts-453A internal php.
following steps:
following steps:
- create new share folder
- create new share folder, only access for admin and hide in network
- i my case the name is "ext_lib" -> after create the path is /share/ext_lib
- i create 3 folders in /share/ext_lib with chmod 755:
/share/ext_lib/etc/config/php.d /share/ext_lib/usr/local/lib /share/ext_lib/usr/local/apache/modules
- load extensions (qts is x86_64)
http://mirror.centos.org/centos/7/sclo/ ... x86_64.rpm
http://mirror.cisp.com/CentOS/7/sclo/x8 ... x86_64.rpm
- extract both
- copy *.so files to /share/ext_lib/usr/local/apache/modules and chmod 755
- change in intl.ini the line with:
to
extension=intl.so
and in apcu.ini the line with:Code: Select all
extension=/share/ext_lib/usr/local/apache/modules/intl.so
toCode: Select all
extension=apcu.so
extension=/share/ext_lib/usr/local/apache/modules/apcu.so
- copy *.ini files to /share/ext_lib/etc/config/php.d and chmod 755
- check dependencies for *.so
- ssh needed
- login, press q and then y to input commands
- check *.so:
ldd /share/ext_lib/usr/local/apache/modules/apcu.so ldd /share/ext_lib/usr/local/apache/modules/intl.so
-> if there an dependency with "not found" you have to install them -> in may case is was libicu*50.so
