PHP.ini reverted and changed after restarting apache
Post your questions about Web Server usage and Apache + PHP + MySQL/SQLite web applications.
Locked
labrax
Post by labrax »
Im on latest php7 and firmware 4.4.1.1117
So I was trying to install Ioncube with editing php ini at
/mnt/HDA_ROOT/.config/php.ini
adding this code to php.ini
zend_extension = /usr/local/apache/modules/ioncube_loader_lin_7.3.so
above "zend_extension = opcache" because ioncube must be load first
but after restarting Apache using "/etc/init.d/Qthttpd.sh restart" php.ini reverted back to original and everything started with "zend_extension = exampletext" will changed to "zend_extension = opcache", I gave it a try from cli and gui still ended up same :( I think this is Qthttpd.sh fault
any help would be appreciated.
labrax
Re: PHP.ini reverted and changed after restarting apache
Post by labrax »
So after wasting hours trying, finally found the culprit by removing this
"|| /sbin/setcfg PHP zend_extension opcache.so -f $PHP_INI"
and everything works after restarted apache.
tumanek
First post
Post by tumanek »
Could you chceck if the solution is correct?
I've got the same problem..
OneCD
Post by OneCD »
Locked
Return to “Web Server & Applications (Apache + PHP + MySQL / SQLite)”
