Hi all,
I have installed joomla through the "Container Station" in QTS 4.4.1. Have SQL Server (MariaDB 5.5.57) enabled. In the initialisation of joomla I have Database type "MySQLi" (I think MariaDB ist synonymous to MySQLi ?). I can connect via phpMyAdmin with the user name/password as configured in the joomla initialisation page. Servername defined in joomla init page is "localhost". When connecting to PHPmyAdmin with the name/pw as in joomla init page i see in the section "Database Server":
Server: Localhost via UNIX socket
Server type: MariaDB
Server connection: SSL is not being used Documentation
Server version: 5.5.57-MariaDB - MariaDB Server
Protocol version: 10
User: joomla@localhost
Server charset: cp1252 West European (latin1)
When joomla is trying to connect to SQL Server in order to initialise the DB, the following error is returned: Could not connect to MySQL server.
When I change Database Type to MySQL (PDO) the following error is returned: Could not connect to PDO: SQLSTATE[HY000] [2002] Can't connect to local MySQL server through socket '/run/mysqld/mysqld.sock' (2 "No such file or directory")
Any suggestions? I do not want to install Postgres SQL as in my humble opinion MariaDB should be capable to accept MySQL connections as defined in joomla.
Thanks for your help.
could not connect to MySQL server
Re: could not connect to MySQL server
did you install a container that has the sql server inside ?
Hi dolbyman
thanks for your help. When I expand "App Joomla" in the Container Station there is an entry for "joomla_web_1 (joomla-without-database 3.8.13) and an entry for joomla_db_1 (MariaDB 10.2). I think that should be joomla with the sql server interface.
In container station "App joomla" editing app environement the following is stated:db:
environment:
MYSQL_DATABASE: joomla
MYSQL_PASSWORD: joomla
MYSQL_ROOT_PASSWORD: admin
MYSQL_USER: joomla
image: mariadb:10.2
web:
environment:
DB_HOST: db
DB_NAME: joomla
DB_PASSWORD: joomla
DB_USER: joomla
image: edhongcy/joomla-without-database:3.8.13
links:
- db:db
ports:
- 10082:80
environment:
MYSQL_USER: joomla
image: mariadb:10.2
web:
environment:
DB_HOST: db
DB_NAME: joomla
DB_PASSWORD: joomla
DB_USER: joomla
links:
- db:db
ports:
- 10082:80
