I’m trying to use my QNAP TS-253D as a web server hosting my webpage. The web page I’m building is in WordPress.
I’m having difficulties with 2 issues.
The first issue is related with accessing the webpage stored in QNAP “Web Server” from a remote location. The second issue is related the configuration of a custom domain.
Issue 1
The problem is that I can’t’ access my webpage while in a remote location, but I’m able to access it when I’m in the same network.
The steps I’ve made are the following:
1. activate the “Web Server” on the “Control Panel”
2. activate “SQL server” on the “Control Panel”
3. configure myQNAPcloud
3.1. enabling “Port forwarding” in my router for the “Web Server” and “Secure Web Server” services
3.2. enabling “My DDNS” service after
3.3. activate “SSL Certificate” purchased from QNAP
4. install and configure “PhpMyAdmin” and “WordPress”
The “PhpMyAdmin” and “WordPress” are in the respective folders inside the QNAP “Web” shared folder
After following those steps I’m able to access my webpage while in the same network with “https://[NAS local IP address]:8081/wordpress/”.
The problem is accessing my webpage from a remote location.
When I use the address “https://[myQNAPcloud DDNS domain name].myqnapcloud.com/wordpress” I get the following error:
When I’m in my local network and use the address “https://[myQNAPcloud DDNS domain name].myqnapcloud.com:8081/wordpress” I get redirected to the address “https://[NAS local IP address]:8081/wordpress/” and my webpage is displayed.
When I’m in a remote location and use that address, I also get redirected to the address “https://[NAS local IP address]:8081/wordpress/” but, obviously, my webpage is not displayed.
What am I doing wrong?
Issue 2
The second issue is related with connecting a custom domain name to my web page.
I’ve purchased a domain name. In the domain management page, which are the addresses namesevers I should use to point my domain to?
I’ve tried [myQNAPcloud DDNS domain name].myqnapcloud.com and [myQNAPcloud DDNS domain name].qcloudnas.com but using www.whatsmydns.net/, the domain isn’t pointed anywhere.
Kind regards,
Jose Mario Gomes
Accessing webpage from remote location + custom domain nameserver
Re: Accessing webpage from remote location + custom domain nameserver
never expose any part of your qnap to WAN..qts or webserver (not secure)
use a vpn to access your nas(does not cost money) ..and a webhoster to host your website
