https not working after installing the SSL certifcate
Post your questions about Web Server usage and Apache + PHP + MySQL/SQLite web applications.
tire1
Post by tire1 »
Hello all,
I have installed a SSL certificate successfully on the NAS server. I checked on SSL configuration on https://www.sslshopper.com/ssl-checker.html and it shows that the SSL is succesfully installed.
But my website is still not using the https and shows unsecure domain.
The 443 and 81 ports are open on NAS. I have tried port 81, 443 in webserver but nothing works.
I would be highly obliged if somebody can provide me step by step guide on it.
Looking forward to hear from you
Best regards
My QNAP Details:
TS-253A
RAID: 1
Firmware version 2.2.2 (latest, I always update it within days of its release)
Mousetick
Experience counts
Re: https not working after installing the SSL certifcate
Post by Mousetick »
If your domain name passed SSL verification by the site you linked to (SSL Shopper), then it's working correctly. And if it's good for that site, it's good for everybody else on the Internet.
So if it's not working for you, the issue must be on the client side. Make sure you're using the correct URL and domain name, and use the browser's diagnostics to find out why it thinks the connection is not secure.
Not sure why you're using port 81 for your public web sites. The standard HTTP port is 80.
Return to “Web Server & Applications (Apache + PHP + MySQL / SQLite)”
