I have a webapp (only on my LAN) running at appname.local. I want to embed my QNAP admin web app in a frame (which I have at qnap.local on my LAN). By default this is not supported, as the X-Frame-Options: header value is SAMEORIGIN.
In Control Panel -> Web Server there is an option "Do not allow Web Server embedding in iFrames." I have disabled it but nothing has changed and embedding still fails. Is web server the admin interface, or something else? How should I accomplish this?
How to make the QNAP admin interface embeddable in a frame?
- jaysona
- Been there, done that
Re: How to make the QNAP admin interface embeddable in a frame?
The control panel is for the (cripled) Apache web server that runs on port 80.
The Admin webpage that runs on 8080 is run by a different web-server. All of the files are located in /home/httpd/ and is controlled by all the crap in /etc/init.d/thttpd.sh
Go spelunking and have fun.
RAID is not a Back-up!
H/W: TS-219 Pro / TS-509 Pro
- jaysona
@jaysona: which QTS version do you use; mine with 4.5.2 looks like mouseticks picture
- jaysona
QTS 45.3.6.1446 - for whatever reason(s), QNAP does not like to make new firmware available to some NAS models, even thought those models technically can use later firmware versions.
