WirelessAP Station - WiFi unification
Post your questions about Web Server usage and Apache + PHP + MySQL/SQLite web applications.
SFX Group
Getting the hang of things
Contact:
Post by SFX Group »
Hi
WirelessAP Station can turn the QNAP in to a Wireless Access point with the use of a PCI-e TP Link card, however does anyone know if there's a plan to link many NAS units together to they are unified so able to see devices use which access point?
Its technically eay to do, one NAS is a masters and the others are slaves all running the same WirelessAP Station app OR the ability of sharing the logs so can see the devices connect to each NAS.
Many Thanks
Many Thanks
Moogle Stiltzkin
Contact:
Re: WirelessAP Station - WiFi unification
Post by Moogle Stiltzkin »
not sure about tplink, but a qwa addon (the old version, not the newer wifi6), you could either
- connect to an existing wireless ap (i tested to my router wifi)
- create a wireless ap. So other devices can connect to the wifi ap on the QNAP directly
NAS
Network
Resources
SFX Group
Contact:
Post by SFX Group »
Moogle Stiltzkin wrote: Wed Apr 07, 2021 2:11 pm not sure about tplink
I took compatibility from this:
https://www.qnap.com/en/app_center/con_ ... 193&os=qts
Many Thanks
Return to “Web Server & Applications (Apache + PHP + MySQL / SQLite)”
