.htaccess rewrite subdomain with wildcard for any subdomain
Post your questions about Web Server usage and Apache + PHP + MySQL/SQLite web applications.
steve102
Know my way around
Contact:
Post by steve102 »
I have many multiple subdomains and would like an example how my .htaccess would look like using a wild card so I can rewrite any http://*.example.com to either goto the root or goto a folder.
This is what I have tried but it does not seem to work. I have activated Rewrites in apache2.
Options +Includes +ExecCGI +FollowSymLinks
RewriteEngine on
RewriteCond %{HTTP_HOST} ^subdomain\.example\.com$ [NC]
RewriteRule ^((?!subdomain/).*)$ example.com $1 [L,NC]
AddType application/x-httpd-cgi .cgi .pl
AddType text/html .htm
AddHandler server-parsed .shtml .sht .html .htm
The above coding is the closest I think I could find . I am new to mod rewrites and their syntax meanings.
I have all my subdomains in my apache2 /etc/apache2/sites-enabled/httpd-vhosts-user.conf.
During my research I have tried many variants but cannot seem to get the syntax.
Like I mentioned, I have many multiple subdomains and have researched on line but with no luck.
**System set up:** I am using ubuntu server 18.04.5, running on a Qnap TS-453D,64-bit x86, Intel® Celeron® J4125 quad-core 2.0 GHz processor, 8GB Mem. Using VirtualizationStation 3 VMs, 6TB Disk Space Raid 5.
Nas1: TS-453D -Firmware: 4.5.3 Build 1652
Nas2: TS-453D -Firmware: 4.5.3 Build 1652
Nas3: TS-253 Pro-Firmware: 4.5.3 Build 1652
Nas4: TS-451+ -Firmware: 4.5.3 Build 1652
Windows 7 | Apple| Linux | Apache | Perl
steve102
Know my way around
Contact:
Re: .htaccess rewrite subdomain with wildcard for any subdomain
Post by steve102 »
The above coding is the closest I think I could find . I am new to mod rewrites and their syntax meanings. .htaccess seems like such a powerful tool. I would like an example of what the code should look like for my needs So, I can better research their meanings and uses.
Thank you!
Return to “Web Server & Applications (Apache + PHP + MySQL / SQLite)”
