Recently I did reset my QNAP and after that, I am having a weird problem. Lots of staff are not working and I assume it's due to WebServer being down. When I try to manually start the webserver it advises updating with the latest firmware. I already did but still cant see any option to start the webserver! Please advise.
Kind regards,
Sandy
QNAP Web Server issue
Re: QNAP Web Server issue
Which NAS model and which firmware version are you running?
- Toxic17
installing a Public Beta firmware riddled with bugs on a NAS that is is clearly a Product NAS needed by staff is not the way to go.
I suggest rolling back to a known working firmware or contact QNAP via submitting a Ticket.
As stated in the images provided by the OP. TS-231+ QTS 5.0.1.2034
Regards Simon
Qnap Downloads
MyQNap.Org Repository
Qnap Downloads
The Webserver is afaik not responsible for any other function of the NAS!
I did not enable the Webserver at some of my NAS devices and do not have any issue.
I agree that its most likely the beta version that causes your problems.
Regards
Regards
Deadbolt - READ 1st post!!!
Deadbolt - information
VPN=VPN? No!
www.raidisnotabackup.com
VPN=VPN? No!
Ooops, didn't look closely enough - sorry.
- Toxic17
if the OP has functions other than a basic web service then the beta and future firmwares will break tons of apps.
Removed support for the following developer tools: Python 2, Node.js v4, Node.js v6, Node.js v8, and Ruby on Rails.
Removed support for the following apps or tools: Mono, Perl, and AlarmClock. We recommend running these apps or tools using Container Station if needed.
Regards Simon
Qnap Downloads
Qnap Downloads
