Web Request Issue to Web Admin utilizing Reverse Proxy
Post your questions about Web Server usage and Apache + PHP + MySQL/SQLite web applications.
smtim
Post by smtim »
Hi everyone,
I will need some help to understand why https://qnapname.myqnapcloud.com request is being redirected to router login page login.php instead of going to QNAP WEB admin login page.
I could see QNAP login page for a second before redirection happens.
When I specify port number like
https://qnapname.myqnapcloud.com:2000 it works
Is the purpose of Reverse Proxy to handle connection and hide non standard port not being displayed on address bar?
1. Router Arris
2. Qnap TS251+ Firmware 5.0.0.1891
3. Web Server is disabled
4. Let's Encrypt Certificate installed
On Control Panel -> Network & File Services - Reverse Proxy Rule is enabled
Source: https://qnapname.myqnapcloud.com:443 Destination: https://qnapIP:2000
On Control Panel -> System -> System Administration port number for https is set to 2000
Router port forwarding has been set up.
When I leave port number as 443 On Control Panel -> System -> System Administration, forwarded on the router and not using Reverse Proxy everything works as expected.
I can get https://qnapname.myqnapcloud.com and get to QNAP WEB admin page.
But there is another issue is security. I am getting constant try to login as admin from different IP addresses. Yes, admin account is disabled.
Still want to get Reverse Proxy working.
I am not sure what I am missing.
Any help is greatly appreciated.
dolbyman
Re: Web Request Issue to Web Admin utilizing Reverse Proxy
Post by dolbyman »
Before you get yourself hacked (check deadb0lt and Qlocker threads) , remove all port forwards and disable UPNP.
Then don't even bother with a reverse proxy (purpose is to translate/abstract all web requests through there to not expose exploits in your QNAP webserver directly) and go with a VPN (costs no subscription) running on your router or a dedicated device like a raspi
Disabling admin account or 2FA is smoke and mirrors and has not helped users that got ransomwared via exploits
FSC830
Experience counts
Post by FSC830 »
And 5.0.0.1891 is afaik not the latest firmware for this NAS. QNAP recommends in latest security advise to update to 5.0.0.2055.
https://www.qnap.com/en/security-advisory/QSA-22-19
Regards
smtim
Post by smtim »
dolbyman wrote: Wed Jun 22, 2022 3:10 am Before you get yourself hacked (check deadb0lt and Qlocker threads) , remove all port forwards and disable UPNP.
Basically if I need an access to my QNAP outside of my LAN, I connect through VPN and than access QNAP through LAN IP address.
Is it right approach?
Thank you.
dolbyman
Post by dolbyman »
That is corret
smtim
Post by smtim »
dolbyman wrote: Wed Jun 22, 2022 5:40 am That is corret
Thanks a lot for your help.
smtim
Post by smtim »
Last question.
Would be QVPN a good candidate for VPN approach?
dolbyman
Post by dolbyman »
No, don't make your NAS an edge device, QVPN had security issues and should not be exposed to WAN
https://www.qnap.com/en/security-advisory/qsa-21-61
Return to “Web Server & Applications (Apache + PHP + MySQL / SQLite)”
