Hey folks,
I just installed WordPress 6 from the App Center. When I try to install a plugin I get the message "the message exceeds the upload max filesize". After I checked the PHP.ini from the settings -> Webserver menue I realised that the max size is already at 2048M.
Where do I have to change the max file size if not in the php.ini?
Hope anyone can help!
Best regards
WordPress upload limit
Re: WordPress upload limit
Best would be to install a current wordpress just plain on the webserver..if you plan to expose it, even better to install it on a VM (does not compromise the whole NAS if hacked)
This was the php settings are probably easier to adjust as well
