Just keeps getting this error message:
Bad Request
Your browser sent a request that this server could not understand.
Reason: You're speaking plain HTTP to an SSL-enabled server port.
Instead use the HTTPS scheme to access this URL, please.
Followed the guide from qnap here: https://www.qnap.com/en/how-to/tutorial ... on-qts-5-0
Tried to manually type https://ipadress but still not working. Any way to get it running?
Help wanted, Wordpress not working
Running QNAP TBS-464 & TS-464 Servers
Re: Help wanted, Wordpress not working
just create a wordpress container ...there is a premade yaml already in container station
Thank you, did not see there where a preset in Container Station. Ended up just downloading the latest from wordpress.org.
Is it more secure running it in a container?
If you are trying to expose it to WAN for sure
Not sure if the wordpress container also has db support (hence the yaml)..you can modify the yaml to just pull ":latest"
