I have a Qnap TS-209 II Pro (firmware 3.3.2), and recently enabled the built in Web Server to access the Transmission admin page.
However, trying to access any of the files through a web browser (from a web browser client on the lan), results in a 403 Forbidden error:
I've tried accessing the root directory, as well as the "/transmission/" directory, and the result is the same.Forbidden
You don't have permission to access / on this server.
Apache/1.3.41 Server at 192.168.xxx.xxx Port 80
Checking the file and folder permissions, they are as follows:
This all looks reasonable to me, with every user type being allowed to at least read the index.html file.drwxrwxrwx 4 admin administ 4096 Aug 9 12:38 Qweb/
drwxrwxrwx 17 admin administ 4096 Feb 13 2008 Joomla/
-rw-r--r-- 1 admin administ 11263 Jan 11 2010 index.html
drwxrwxrwx 11 admin administ 4096 Aug 21 2007 phpMyAdmin/
lrwxrwxrwx 1 admin administ 48 Aug 9 12:38 transmission -> /share/MD0_DATA/.qpkg/Transmission/web-gui/admin/
Searching the forums, I only found solutions to this sort of problem that referenced "getfacl", which is a command unavailable in my shell. I think this command is most likely a feature of newer firmwares, built for newer hardware revisions.
At the moment, the group "everyone" does not have any access check-boxes ticked. I did try ticking the RO "Qweb" box for this group, but this did not seem to have an effect.
Does anyone know whether I could be missing some settings in the Access Right Management control panel?
